Question about Troy Bilt 5.5hp Self Propelled Mower
Blade control will not engage. Engine will not start.
Engine is not firing at all. Gas is getting to the plug. Plug seems good. The cable on the blade control doesn't seem to move anything when I pull the handle down so I think the problem is with the blade control cable/kill switch. Any ideas on how to fix that or what I should see it doing when I pull the handle?
    Problem Solver:
  • 13 Answers
Well, If it worked last time...I would say it is the gas..moisture..
if not, then both ends of your cable. If nothing moves. it is either broke or came undone from lever by engine. I lean toward the gas, especially if it sat up all winter. (A new plug would be a good idea,Stranger things have happened) I had to do that to mine.
Posted on Mar 23, 2014
Mower won't start
What kind of engine do you have? Have you done the typical checks like nothing is stopping the blade from moving under the deck, the air cleaner is ok, the plug wire is on, stuff like that? Is you gas clean? Too much compression sounds like something under the deck or something pulling on the blade, like a rope was picked up or a wire. Check there first.
May 19, 2012 | Garden
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
My Craftlman lawn mower stopped running in the middle of mowing the lawn. Engine YTPXS.1951BA Engine model 143.016722. The rope would not pull and the blade would not move. Checked the dip stick, no oil....
Either the magneto or the off switch is stuck in closed position, If you have dead man's control make sure that it is activated when you go to start the motor.
Apr 27, 2017 | Garden
Engine starts and runs okay until I engage blade
I had the same problem on a 21HP, you are running on one cylinder. Take off the valve cover and most likely you will have a/some bent valve push rod(s) which is common on B&S V2 engines. They are cheap to buy but kind of tricky to install and properly adjust.
Jul 06, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
NO SPARK, SPARK PLUG GOOD,COIL GOOD AND CARB. GOOD, IS THERE A SAFETY SWITCH SOMEWHERE CAUSING THIS?
Hi..my name is Keith..and to answer your question..Yes there is several safety switches that will keep your engine from starting..i would check the seat switch..the neutral safety switch and the blade engaged switch..the clutch/brake switch...if all these check good..then write me back and i will help your further
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawm mower back fires and kills when blade is engaged
Check your spark plug. Or maybe your choke is stuck
Jun 19, 2009 | Craftsman Garden
Engine runs but blade doesnot
The clutch is not engaging or the linkage to the eccentric that moves the blade is not connected.
May 26, 2009 | Homelite Factory Reconditioned 26cc...
1998 craftsman mower w/19.5 hp Briggs and Stratton will not fire.
Hello B-N-L:
>>I Suggest you Check the Ign Module First and then the Safety Switches if the Ign Module (Coil) is Good. Remember that the Ign Module May Check Good, but if the Safety Switches Check Good, then Most likely the Coil is in the Early Stages of Breaking Down and will Cause this Problem.
>>You can Check the Ign Module (Coil) by Using the Following Instruction File.
The Following is an Instruction File I Made for Checking and Repairing this Problem.
>>Run the Engine Until it Quits, then Remove the Spark Plug. Wrap a Wire Around the Threads and Attach the Other End of the Wire to the Engine Block Turn the Engine and See if the Plug Fires.
>>If No, then Disconnect the Shut Off Wire at the Control Bracket First, Check for Fire at the Plug. If Still No Fire at the Plug; Then Disconnect the Shut Off Wire at the Coil (usually requires removal of the blower housing) and Check for Fire at the Plug.
>>If No Fire at the Plug , then the Coil/Ign Module is Bad. The Coil/Ign Module to Flywheel Gap is .020in.
>>On Some Model JD Engines, there is a Igniter that Goes Bad and Not the Coil. The Igniter is the Same as an Ignition Module. If the Plug Fires at Anytime During these 2 Checks, then a Safety Switch or Wire May be the Problem. Yes the Engine will Turn Even with a Bad Seat Safety Safety Switch. Usually if the Engine will Not Turn with the Ign Switch; the Blade Safety or Neutral/Clutch Safety Switch is Usually the Cause of this.
>>The Starter Turns and the Engine Doesn't Fire is an Indication of a Bad Coil/Ign Module or a Faulty Blade Safety Switch.
>>The Blade and Clutch Safety Switches Prevent the Starter from Engaging so the Blades or the Mower Does Not Move when the Starter Turns the Engine.
>>The Seat Safety is Designed to Stop the Engine if the Blades are Engaged or the Clutch Safety is Not Engaged when you Leave the Seat.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire.
>>Check the Clutch/Brake and the Blade/PTO Safety Switches First.
>>Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Volt/OHM/Continuity Meter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>If the Safety Switches Check Good, then Check the Ign Module (Coil).
>>Thanks.
Respectfully
John
Apr 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Stalling Briggs & Stratton engine
carbeurator needs torn apart..cleaned and reset.
Sep 01, 2008 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
56 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
