Question about Dyson DC14 All Floors Upright Vacuum Cleaner
How do i take off the switch on dyson dc14
I press the switch to turn on and nothing......
    Problem Solver:
  • 7 Answers
5 Suggested Answers
  • 183 Answers
SOURCE: My Dyson DC14 won't turn
Well you might want to change the fuse in the plug then make sure the cable hasnt been cut
Posted on Aug 02, 2010
kevster6720
  • 171 Answers
SOURCE: Dyson DC14 animal shut down, now won't turn on
This coul;d be a couple thing, it could be that the machine is full and shut off due to a heat sensor. You should see if it has a reset button on it for the power head. I don't think it does so I would empty it out and clean the filter and try it again. Also did you try it in another plug in as you may have blown the breaker.also if the dirt container is not in just right it will not turn on as threre is a safety switch so it can not be run without the dirt container. Try these things and if you have npo luck write back and we will try again.
Posted on Oct 08, 2010
SOURCE: my dyson dc14 wont turn on at all
Hi I would suggest you first check the Fuse in the plug. This is quite common.
If after chnaging the fuse the machine still doesnt work then please come back to us. Let us know that you have checked the fuse andthe machine still wont switch on.
Im confident it will only be the fuse. Unless you have had strange noises or funny smells coming from the machine.
Posted on Oct 27, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson DC14 just shut off. No bruning smell. Is
Start by checking the filters and washing them. There is a tutorial here: Dyson advice.
Posted on Nov 30, 2010
Tried pressing in red button and switch next to on button to get roller working but not made any difference - still wont turn (any no suction)
I'm sorry to hear you're having difficulty with your DC24. If you haven't been able to reset the brushbar using the reset switch on the cleaner head, I'd encourage you to get in touch with us directly so we can provide further assistance. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
We'll look forward to helping you resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 31, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
My Dyson Aminal Vacuum simply will not turn on. I plugged it in this morning, pressed the power button- and nothing. No warning sounds, simply silence. Sigh. Nothing is wrong with the wall outlet.The...
The power switch may need to be replaced. Call the Dyson helpline - they will give you the location of an authorized Dyson dealer in your area who will be able to replace the switch.
Jul 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stopped Spinning
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold
the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 12, 2009 | Dyson DC25 All Floors Bagless Upright...
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Not working,need assistance from anybody or cheap parts.thanks
sounds like the trigger switch is stuck.try to spray a little wd40 up into the switch and work it ,maybe it will free up.if not the switch is probably bad
Apr 29, 2009 | Vacuums
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Machine will not work, i plug it in and press the power, but nothing happens.
I have the same problem with my shark. I dismantled it and found that a thermal fuse on the bottom of the tank is blown. I am trying to locate the part now. I will post when found.
Jun 10, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Dyson DC14 All Floors Upright Vacuum Cleaner Logo
95 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
