Question about Califone International Audio Players & Recorders
Platter not spinning
I just bought a Califone 1420k, turned it on, but the platter does not spin. The light on the tone arm turns on and I can hear a tone coming from the speaker so there is power. Any suggestions what could be causing this?
  • Califone Int... Master
  • 5,126 Answers
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Posted on Mar 26, 2014
4 Suggested Answers
  • 1126 Answers
SOURCE: JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Posted on Jun 23, 2009
  • 133 Answers
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
  • 31 Answers
SOURCE: platter wont spin on stanton
The belt that drives the platter may have shifter or the gears that turn the platter may be unaligned. Open it up yourself and check out the inside but be careful not to break anything or go into a local music/dj store. they may be able to help you for cheap or for free.
Posted on Mar 02, 2011
Why does my Califone 1400 plate sound loud?
The rubber idler wheel that turns the platter may be worn out and may be hardened with age. If the rubber is not pliable the wheel turning against the metal platter will cause a noise. It may require a new rubber motor idler wheel.
Apr 27, 2014 | Califone International Audio Players &...
The turn table on my record player wont spin I can hear that it's on put wont spin.please somebody help
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of courseicon1.png, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Oct 29, 2013 | Crosley CR249TA Turntable
Is this a belt driven model? If so then just replace the belt. Also check that platter can turn. Sometimes grease or dirt builds up. If you can't turn it by hand then neither can the motor.
Feb 16, 2013 | Audio Players & Recorders
Platter wont spin on stanton t 120, all the lights turn on fine, platter seems to feel jammed, it wont spin easily when i push it by hand.
Mar 02, 2011 | Stanton T.120 Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
The turntable won't spin
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Apr 10, 2010 | Crosley CR248 Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
The record won't turn at all....maybe the motor? speakers work, radio works. needle goes over but goes right back cause record isn't spinning. (just bought it last night, so i really have no idea how to...
check if the platter spins if you manually turn it.
The platter is motor driven either directly (rarely), by a belt or by a rubber idler. The only way to know is to remove the platter or by model # (which is not listed on this post.)
Check the platter and post back with the model/make in the body of your post.
Oct 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
115 people viewed this question
Top Califone International Audio Players & Recorders Experts
Ben Armstrong
 Bob Buchholz
Bob Buchholz
 Grubhead
Grubhead
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
