No power hi i have a lexsoe lc27w18sd tv which has no power at all not even the blue light when plugged in and turned on , ive tried the plug and fuse, no joy any ideas, i have it turned on by the main but the tv shows no life at all no standby light nothing. any help would be great thanks
snakehead
  • 1074 Answers
SOURCE: Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
  • 44 Answers
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 188 Answers
SOURCE: Phillips 42PFP5532d/05 LCD tv, stuck in standby.
Check 15V line,12volts is too low.
Posted on Jul 27, 2009
  • 979 Answers
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Posted on Apr 15, 2010
Testimonial: "how helpfull thanku kindly !"
When i plug in the tv nothing happens. the red stand by light does not even turn on.
Hi Frazier,
The power supply board of your TV needs to be repaired or replaced.
Apr 15, 2016 | Televison & Video
My tv is keep turning itself on and off and my remote has randomly stopped working, ive had the plug out the wall the past 6 hours nd no joy, any ideas? I've put new batteries in the remote 2
Sounds like a power board issue? Dry joints on the main board? Capacitors may have issues.? I would not go opening up the TV if you are not aware of the potential dangers.
Mar 25, 2015 | Luxor LE40WTUD-B 40 Plasma/LCD/TV Cart
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
Cannot locate internal fuse in my Toshiba 32DV504B
Contact any service technician. The fuse can be located at its main power supply regulator board itself. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Toshiba Televison & Video
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
For the past couple of days when switching the tv on the blue light flashes but tv doesnt go on, then this morning i turned tv on and was watching it, out of the blue the tv made a sound and turned off,...
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 17, 2010 | Televison & Video
My Tv just **** off randomly, and now it won't
Hi.
Bad power supply, open the TV to check the fuse and bad caps, if you are not tech savy , just order a new one
LG 6709900017A Power Supply
and go to your local shop to put
Feb 24, 2010 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
