Question about GE 1992 Mercedes Benz 500SL Instrument Cluster Bulb
How to install a belt tensioner adjuster on a 92 mercedes benz 500sl
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Belt tensioner is on right hand front of engine slacken it off full and use bolt head to turn centre piece until desired tension then lock
Posted on Jun 20, 2014
I replaced both belts on rollers after the drive belt broke and now the rollers do not spin when I try to operate it. Is there a reset button I am not seeing?
It sounds like the belts need adjusting. The instructions that came with the belts should explain how to adjust the belt tension. Additionally check for debris around the brushes. This may be the reason for the belts breaking to begin with. Without the belts on the brushes should turn freely by hand. If that doesn't do you can call Consumer Care 1-800-237-7691. Hope that helps.
Nov 14, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
My brush won't rotate. i have replaced the belt once already but it melted because the only thing rotating was the motor pulley. I have cleaned all the excess hair off the brush, checked everything, and...
The most probable cause is improper tension on the belt. What would cause this problem is the wrong belt, or improper adjustment of belt. Once installed, the belt should only move slightly when pushed down by your finger. Too loose and the belt won't rotate the brush and will quickly burn out. Too tight and it will cause excessive stress on the motor and shorten it's lifespan.
Another problem could be that the belt wasn't centered properly. When the new belt is installed, the brush needs to be manually rotated a few times to center it. This will prevent it from getting caught in or on a part of the power head, thus quickly breaking or melting.
If you still have problems you may need to take it to a reliable service center.
Dec 21, 2010 | Bissell 3576 CleanView II Bagless Upright...
Beater bar does not turn. Belt is not broken but is so slack that it won't turn the bar. Do I need a new belt or is there a way to adjust the tension?
No, once the belt is stretched and worn there is nothing you can do, you have to replace them. Here is the belts you need for your model:
Hoover U6476-900 Belts
Apr 08, 2010 | Hoover U6476-900 WindTunnel Vacuum
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Dec 16, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Where does he belt slide over the shaft
hi there,
there is are two way,adjust the tension of belt from motor to pulley of vacuum maybe loosen,or replace the tension belt from motor to pulley already worn out,replacement should be done by qualified appliance technician near your home or service center.
Jul 05, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Belt tension adjustment
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
New Hoover belt nbr 385280-34 installed, belt still too loose.
There is no adjustment. As they wear they cut the groove in the roller deeper. Sure fix,and what Hoover will tell you to do is to replace the roller. If your like me though that isn't any good. so what I did was wind wax coated dental floss into the groove that the belt rides in and in and then put a couple of drops of super glue to hold the end and it works like a charm. Don't put too much in there the belt has to have a groove to ride in.
How do you adjust the tension of the v-belt on the u6630-900
Hi! I'm not so familiar with this model, but I believe the V-belt is only under tension when the brush roll  control is in the "HARD" or "OFF" position. I'm not sure what the exact mechanism is, but I suspect that moving the control to the "ON" position is what places the belt under the correct tension and thus drives the roller.  Please let me know if I'm right! As for your other point, not sure what you mean by the "hood assembly cover" or why you might want to take it off. If you can clarify, I'll help if I can.
Feb 25, 2009 | Hoover U6630-900 WindTunnel Bagless...
GE 1992 Mercedes Benz 500SL Instrument Cluster Bulb Logo
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Are you a GE Vacuum Expert? Answer questions, earn points and help others
