Question about Ryobi Garden
Roybi bc 30 trimmer carb problems
Mine would not stay running so i cleaned out carb.now it idles on the a choke setting but will not on the b and c setting.evrything is tight,right gas&oil mix.there are two plastic cams or screws on the bottom of the carb,are these the air fuel mixtures screws? air filter is clean too.it seems to be starving for fuel wont rev up under power.
  • 1 more comment
  • stopurcryin Jun 15, 2009
    the plastic screws you are talking about is one white and the other red?they are on the bottom of carb.they look like cams.are there screws behind them or are those the screws?
  • panilling9
    panilling9 May 11, 2010
    yes for the red and white or clear
    there is screws behind them the plastic caps limit the turns of the screws
  • panilling9
    plastic screws need adjustment
    but they only turn so far
    how you make them turn further is up to you
    (service people only have the tool to remove these caps without destroying them)
    so if you find a way come out a 1/4 turn on both and try
  • 1,041 Answers
First, check fuel lines for cracks/breaks. Replace if they are bad.
Next, you will need to do a little bit more detail on the car.
Disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. ( You should be able to see daylight through it.) IMPORTANT: Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
  • Jim Parker
    Jim Parker Jun 18, 2009
    Did this solution solve the problem?
    Jim
Trimmer has to stay between half choke and full choke to stay running what is it
Start with carb adjustment. One full turn out on both low and high side, then set the idle. If this doesn't fix it, then rebuild the carb.
Aug 26, 2014 | Ryobi Garden
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
MY RYOBI BC 30 WILL NOT RUN WHEN I SET TO C FULL
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Jun 29, 2009 | Ryobi Garden
My weed wacker wont stay running .It starts and runs in choke and the next setting up ,but only 30 seconds to about 2 min.Does anyone have an idea why
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Jim
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine will not throttle up
the red and white screws are the air and fuel mixture needles they may need adjustment if you are getting plenty of fuel to the carb. note that newer walbro carbs these mix set screws can only be adjuted very little. they will break if you twist to much. but firt when you took the carb apart was the fuel metering diaphram crisp or was it still flexable? ( black gasket thing under side cover . it has a small metal botton in the middle of it. if this does not flex freely then you need a walbro carb gasket set. mabe 5 to 10 bucks.
Jun 08, 2009 | Ryobi Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
302 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
