Question about Mattel GirlTech Password Journal 6
Need new pad
Were can i get a replacement pad
Proper brake pad replacement procedure for 2007 saturn aura
The proper replacment proceedures for saturn aura brake pads front is to take off your wheels, unbolt the caliper housing on it. You should also replace the shims when you replace the brake pads, it's the metal brackets around the pads. The new brake pads slide into place. If i was you I would also replace the caliper pin boots with new ones aftermarket. My car had a warping issue and a uneven brake pad wear and this fixed both problems. Need anything else ask, the tire should be retorqued to 100ft/lbs when you reassemble everything.
Sep 02, 2010 | 2007 Saturn Aura XR Sedan
MY LOGITIC MOUSE NEDS NEW PADS ON THE BOTTOM OF IT .CAN YOU BUY NEW ONES? ONE OF THE PADS IS MISSING CAN YOU REPLACE THEM?
THERE IS NO NEED TO REPLACE PADS MOUSE WORKS WITHOUT PADS. YOU MAY INSTEAD OF IT USE SEPARATE MOUSE PAD AVAILABLE IN MAY SHAPES/DESIGNS
Aug 16, 2010 | Logitech Cordless Mouse
Scroll is not working
This could be one or some of the 3 issues that may be happening with your notebook or netbook:
1) check control panel (if this is windows) and click on touch pad icon and make sure the sofware to control the touch pad is working and it's on.
2) If it is on, reinstall all touch pad and mouse drivers for this unit by going to the manufature's website and downloading the original drivers for this unit
3) it that does not work, you may have a defective or broken touch pad and it may need replacing
BEFORE CONTEMPLATING A NEW TOUCH PAD, do 1 and 2 first.
They are usually the main causes of touch pad failure and should resolve your issue.
If both fails you may need to order a new part to replace the pad.
I hope this helps. Write me back and let me know how it goes
Jun 14, 2010 | Compaq (153515-001) Touch Pad
Touch screen not working help me
the touch pad of your phone is faulty it needs to be replaced.
To replace the touch screen, you need to get a new touch pad.
When you purchase the new touch pad,you have to loose the phone to gain access to the faulty touch pad.You will needing a soldering iron to replace the touch pad.
If you do not have the technical know how of fixing the touch pad, i would advice that you give it to an expert so that you will not damage anything further.
Have a nice day.
Mar 15, 2010 | Sony Ericsson P900
Replace rear brake pads brakes
You'll need to turn the caliper pistons in to allow the new pads to fit over the rotor.
Jan 17, 2010 | 1990 Subaru Legacy
I'm replacing the brake pads but don't have money for new discs right now. Is it ok to put on new pads for a couple of weeks and then new discs?
Disk's and pads are the same thing,Brake pads,Brake disk.
Are you meaning the rotor?
If you are the answer is yes,you don't have to replace the rotors unless you have a rotor brake vibration when you are applying the brakes on your car.
If you do want to change rotors later,you can but remember to take sand paper to the previous new pads,because they were used and got hot and hard they will now score the new rotors,that is why you sand the pads.
Dec 31, 2009 | Kia Sportage LX Cars & Trucks
How to change out front brake pads on a 2001 mazda 626?
remove 2 caliper bolts, remove old pads. put new pads in there place, before installing the caliper, be sure to squeeze the piston back in the caliper otherwise it will not fit back over the new pads. than replace the caliper and the 2 mounting bolts.
May 07, 2009 | 1995 Mazda 626
Uneven wear on new brake pads
sounds like the caliper slides are frozen /also make sure you have the right pads for the application
Dec 09, 2008 | 2003 Ford F250 Super Duty Crew Cab
Installing new brake pads on 2000 hyundai Accent GL
REMOVAL 8118049.gif 1. Remove the lower bolt and lift the caliper assembly up and secure it with a wire or some other retaining method. 2. Remove the pads. CAUTION: Do not depress the brake pedal while disassembling the pads 30c09b4.gif
INSPECTION 1. Check the pads for wear or oil contamination and replace, if necessary. caution_icon.gif The pads for the right and left wheels should be replaced at the same time. Never "drop" or intermix brake pad sets. All four pads must be replaced as a complete set. When replacing the brake pad, check for deformation. When replacing the guide spring, use a new one or the used one after cleaning away foreign material. 2. Check the pad for damage or deformation. Brake pad thickness: Standard value: 9 mm (0.354 in.) Service limited value: 2 mm (0.0787 in.)21873bf.gif
INSTALLATION 1. Install the pad clips. 2. Install the pads onto each pad clip.
3. Insert the piston in the cylinder using the Special Tool (09581-11000).b3dcdee.gif 4. Install the new pads. The shims are attached to each pad as illustrated5efc485.gif caution_icon.gif Be careful so that the disc or pad isn't contaminated by grease. 5. Install the bolt and tighten to the specified value. Tightening torque Guide rod bolt: 22~32 Nm(220~320 kgf·cm, 16~24 lb·ft)
Jun 11, 2008 | 2000 Hyundai Accent
Mattel GirlTech Password Journal 6 Logo
15 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
Tracy E
Level 1 Expert
Are you a Mattel Toy Expert? Answer questions, earn points and help others
