Toshiba 32av500u Where is bulb located on tv for the picture
Slapnuts1975
  • 51 Answers
SOURCE: When I Turn on my toshiba 32AV500U there is sound but no picture
The problem isn't with the lcd panel, its with toshiba not willing to sell the backlight master or slave inverters seperately from the panel. If you check either the master or slave will have a blown 5 amp fuse, ussually 2 or more transistors inline with the transformer will be shorted.
Posted on May 26, 2009
  • 15 Answers
SOURCE: My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Posted on Mar 17, 2010
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
  • 473 Answers
SOURCE: my toshiba 32 inch lcd tv has green ,red,and
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Posted on Sep 21, 2010
SOURCE: Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Posted on Feb 21, 2011
Where is the bulb located on a hd56w66 tv
If you have a HD56W66 it is not a DLP set it is a rear projection Tv set . id does not have a bulb it has three picture tubes one in red blue and green
Oct 20, 2014 | RCA Televison & Video
Mitsubishi wd 73838 tv no picture, I replaced the bulb and now the tv has sound and no picture with a solid red light
It may be a fuse, they are located on the back on the unit. If that doesn't work, go to their web site for additional assistance
Sep 20, 2014 | Televison & Video
Picture bulb location?
Please explain what you mean by picture bulb?
Aug 03, 2014 | Haier Le46b1381 46" 1080p Led-lcd Tv -...
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
No picture but I have sound.
U have not change the projection bulb for this tv at lest 2 years,and u used the tv alots?The first thing u require to do is to change the projection bulb.See what happen,than go from there.
Apr 24, 2010 | Akai PT5598HD 55" Rear Projection...
I have a 50'' Philips tv. When I turn it on the picture comes on fine, within a matter of minutes the picture goes out and this red light comes on highlighting a tiny picture of a light bulb on the ''on...
Sounds like your lamp is bad. I think this is the set where you have to take the whole back off to replace the lamp. Once you take the back off, its on the left hand side.
Dec 02, 2009 | Philips 50PL9126D/37B 50" DLP TV
Turn tv on, sound comes on but no picture, power light blinks,
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
Apr 08, 2009 | RCA P61940 61" Rear Projection Television
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
