Question about Sony STR-DG800 Receiver
I HAVE A SONY STR-KG700 5.1 SISTEM, AND SOON I`LL MOVE TO EUROPE. MY QUESTION IS : HOW TO MAKE IT WORK WITH 220 VOLTS? CAN THE POWER BLOCK (OR THE TRANSFORMER)BE CHANGED?
  • 986 Answers
I would just buy a transformer for the unit 220 to 120. That way when you move back your good to go.
Posted on Jun 14, 2009
Electricial problems wrong voltage used . have a kenmore dryer, sent dryer to europe and was connected to two circuit like in the US but the voltage in europe is 1 curcuit 240 volts and 2 circuit 400...
The dryer has sone things inside that require 110 volts. Specifically the motor and the timer. Therefore if by some chance that you haven't yet damaged anything, it still will not run until you have a 220 volt center tapped transformer to similate US power (220 volts with a neutral). Also, since the foreign power is 50 Hertz, the timer will run slow (5/6th speed) as will the motor. And the motor, being designed for 60 Hertz, will run unusually warm.
Nov 29, 2009 | Kenmore Dryers
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
Will a Canon Pixma MP 160 printer work in europe running 220 volt
Have a look on the markings on the adaptor. There it will be mentioned ---input voltage ---- 115V or 220V
If both 115 and 220 are mentioned it will automatically handle voltage differences.
Please make sure to avoid burning.
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Hcd bc150 main power
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Aug 31, 2008 | Sony DAV-BC150 System
Converter needed
If your unit is from the USA, 120 volt/ 300 watts.
EU is 220-240V / 300 Watts. Best choice is to go to Bose service center in EU and have your transformer inside your box replaced with 220-240V for EU operation. That way you don't have to worry about a converter. If not, 2nd choice is buy a step-down transformer 220-240V input and 120 Volt output that can handle 300Watts.
Good Luck.
Dec 22, 2007 | Bose 3 2 1 GSX System
Sony STR-DE705 question
yes you can use a step down converter,but remember to use a higher rating converter.if your receiver need 100w ( or 1A )then you need a converter at least give 150w ( or 2A ).
Aug 06, 2007 | Sony STR-DE705 Receiver
Sony STR-DG800 Receiver Logo
861 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
