Lcd tv white screen
We bought this tv new but when we set it up it had this white crisp smear on the left side. the smear has thin colored pinstripes within it. The menu is underneath it and the curser can move underneath and you can press on 'something 'and it will work. you only can see the picture on the part that does not have the smear. We exchanged the tv and the new one does the same thing except the smear hiding the menu is in the centre, the picture shows o both sides but you cannot see what is going on in the middle. Is this a problem with this tv or are we having connection issues and if so what are they.
  • 3,320 Answers
OK. Great idea to try another monitor! What you forgot was to tell us the make and model. Also we need the make and model of what you're connecting the monitor to.
That said, it could be the cable and connectors: are you using an adapter to match up with a specific connector?
It could be a resolution setting on the monitor or on the video card. Both have menus for adjusting the input signals.
Posted on Mar 28, 2014
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
New 60" lg TV has a crisp white smear with pinstriped lines
Bring it back. You have done nothing wrong and the dealer may have a Bad Batch of units.
Mar 22, 2014 | Computers & Internet
Color smeared
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 05, 2017 | Philips 42pf9966 42-inch Hd-ready Flat...
I have vertical bars on screen
The T CON board of the television is bad, you need to replace this
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helps........
Jul 30, 2010 | Sony KDF-E55A20 55 in. LCD Television
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
Feb 19, 2008 | Planar WS231 23.1 in. Flat Panel LCD...
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
