When I turn it on it turns on and off about 30 times before it stays on
Once one for a while I have no issues turning it on and off
    Habit-Forming:
    New Friend:
  • 173 Answers
It could be a defective (shorted) horizontal output transistor. Thanks for using Fixya.
Posted on Mar 23, 2014
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: we have a Sony rear
The problem on your tv is the leaky electroltytic capacitor on the regulator section.
Replaced the capacitor on that area and your unit will be back to normal again.
If you don't have an experience in electronics find a qualified technician to do the job for you.
Have a nice day!
Thanks for using fixya.
JDVillanueva
Posted on Feb 03, 2011
My 2003 saturn lw200 will start but will not stay running. The lock light has came on but is now off. how do i reset the anti theft
If it is just a relearn and you have no issues with the security system the procedure to "teach" the vehicle the transponder code for the "chip" in your key is as follows. Turn the ignition and just turn the key enough so the engine turns for just a second. Not enough to try and start the vehicle jusy enough to "bump" the engine quickly. Once you bump the engine, release the key and leave the key in the "on" or "running" position. Your security light should be flashing if you're dealing with a security issue but that doesn't happen 100 percent of the time. Leave the key in the on position for 10 minutes. If the security light is on or flashing it should shut off after 10 minutes. After the 10 minutes turn the key off and without removing the key turn it to where you bump the engine like before and repeat the 10 minute wait time. You will need to do this 3 times totalling 30 minutes. The 3rd time turn the key back off and without removing the key try and start the vehicle. This is the only procedure that can be done without diagnostic equipment and providing you don't have an issue with a part in the security system or there isn't another problem, this should reprogram your vehicles security system. Hope this works for you and hope I was able to help....
Oct 11, 2013 | Vehicle Parts & Accessories
1999 gmc savanna 3500 van, reprogram ignigtion key
place the key in the ignition and turn on.leave on for ten minutes.once ten minutes is up security light will either flash or go out.then turn off and then on again.repeat 3 times.this is a 30 minute relearn.remember just turn the key to run not start.good luck
Dec 14, 2011 | GMC Vehicle Parts & Accessories
Headlights stay on too long after turning off ignition
This is a feature for safety. If you turn off headlights before the engine, they go out immediately.
If you leave lights on when turning engine off, then turn off headlights, they stay on for approx 30 - 40 seconds, to allow one to walk to the door etc, with illumination on.
If you mean several mins, then time it to check consistancy. If consistant, may be a program issue, if not consistant, maybe a relay issue.
Aug 11, 2011 | 2005 Dodge Caravan
I have a Coby 42" tv that is a year old that turns
Check your electrical outlet. We had same issue with a different brand TV and the electrical outlet was the issue. Hope this helps.
Jan 11, 2011 | Coby TF-TV4209 42 in. HDTV LCD Television
My issue is with my a/c on my 1992 Road Master i bought car from someone they said that they had just recharged a/c a couple weeks ago. I used a/c a few times with no issue. Then i noticed when i would...
take out the a/c and climate control fuse. THe climate control display will count down from 30 seconds two times. That will reset the climate control module. Worked for me :) problem solved
Jul 01, 2010 | 1992 Buick Roadmaster
Replaced lamp, still does not turn on.
LAMP #BP96-00826A
IF THE TV STAYS ON FOR 30 SECONDS IT MAY BE AN INDICATOR OF A POSSIBLE POSITIONING ISSUE WITH THE LAMP DOOR SWITCH (LITTLE BLUE SWITCH AT LOWER LEFT OF CABINET WHEN LAMP DOOR IS REMOVED.) THIS SWITCH IS SUPPOSE TO BE IN THE DOWN POSITION ONCE THE LAMP DOOR IS SECURED AND HAS CAUSED CONFUSION BEFORE.
HOPE THIS HELPS
Jul 06, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony Wega turns on and off and on and off... HELP!
It could be the bulb, but most likely it is power supply. Very common in rear projections. It could be a ballast issue, but if the color wheel is spinning, than the problem is most likely faulty power supply. You can test the supply with multimeter to check current.
May 30, 2009 | Sony Televison & Video
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Plenio VXA-3000 Navigation Unit, powers on but screen stays off.
If you Need Plenio Tech Support
www.dvssale.com
Dan Kim 408-970-3388 office
DVS Sales Inc.
2398 Walsh Ave.
Santa Clara, CA. 95051
Email kimus@dvs.co.kr
posted 01.15.2009
jeffreydrescher@Bellsouth.net
Jun 01, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
