New 60" lg TV has a crisp white smear with pinstriped lines
This is a new tv, we connected it and found the white smear on the1/3 left side of the screen. the tv works but you cannot see it where the smear is. It is crisp looking with vertical coloured pinstriped lines in it. The menu was underneath it and you could not see it but the curser would go underneath the white smear and would work. We did not know what we were pressing. we exchanged it but the 2nd new tv did the same thing except the smear was in the center. It was also covering the menu and the tv worked clearly on both sides of the smear. It this a problem with the tv or are we somehow having connection issues
  • 790 Answers
Bring it back. You have done nothing wrong and the dealer may have a Bad Batch of units.
Posted on Mar 22, 2014
unclejed
  • 26 Answers
SOURCE: Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Posted on Jun 28, 2006
  • 4 Answers
SOURCE: Plasma tv has no picture only sound.
IF U HAVE A INTINA U SHOULD PROBLY MOVE IT IF U DO NOT U SHOULD CALL A CABLE COMPONY ABOUT IT TRUST ME
Posted on May 11, 2008
SOURCE: LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Posted on Jul 23, 2008
Smooth_Gecko
  • 125 Answers
SOURCE: a vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Posted on Jul 30, 2009
  • 17 Answers
SOURCE: LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Posted on Mar 22, 2010
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
My TV has a white vertical line about 8 in wide on the right side of the screen followed by a few blurry vertical line going toward the center of the screen the left side is fine
More burned capacitors.. You have a center and sometimes a right and left circuit board. If you have to visit the board more than once in just a few months you will have to call the LG tech. You need to replace one of the boards. I tried the self repair route and nearly ruined the TV. Take it from me ...call the tech.
Jul 06, 2015 | LG 60PV250 60 in. Plasma HDTV
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
Why comes white vertical line on my t.v?
Horizontal scan output fault. Check the connections to the deflection yoke from the main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 27, 2015 | LG Televison & Video
Lcd tv white screen
OK. Great idea to try another monitor! What you forgot was to tell us the make and model. Also we need the make and model of what you're connecting the monitor to.
That said, it could be the cable and connectors: are you using an adapter to match up with a specific connector?
It could be a resolution setting on the monitor or on the video card. Both have menus for adjusting the input signals.
Mar 22, 2014 | Computers & Internet
Black and white vertical lines on left sided of screen. Black and white vertical lines vary in width. Left of vertical lines is wrapped video from right side. This is happening on all inputs. I have very...
If its under warranty take it back immediately!!! If not you will need to have the set diagnosed to pinpoint the problem. You could be looking at a faulty t-con/panel connection (easy fix) or a bad t-con board(inexpensive) or a LCD panel(very expensive) failure !
Oct 08, 2013 | Samsung UN60C6300 60 in LCD TV
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
