Question about Vehicle Parts & Accessories
Wildfire atv wiring diagrams
Can't find where green wire off coil goes
    New Friend:
Green typically goes to ground but no guarantees
Posted on Apr 15, 2014
Could anyone tell me or show me a diagram of which wires belong on each side of the ignition coil? 1985 Chrysler town and country Woodie wagon 2.6L-2 carbureted 4 cylinder Mitsubishi motor
The two wire coil will have a black wire to the negative side terminal and the other wire may be dark green or brown according to two different sources. Either way the black goes to negative and the other remaining wire goes to the positive side.
Apr 21, 2016 | Chrysler Cars & Trucks
On a 1998 chevy cavalier what color wire do i hook the green off my tach to
The green wire from the tach goes to the negative side of the coil or if its an HEI distributor it will connect to the left of the hot wire going. to the distributor.
Apr 01, 2014 | 1998 Chevrolet Cavalier
go to www.clubdediagramas.com tranlate the website and get it
Otherwise you must go
https://www.samswebsite.com/
God bless you
Jul 28, 2013 | ATVs
Wiring harness to the distributor
I am sorry but fixya has no wiring diagrams.
Jul 23, 2012 | 1990 Ford Mustang
Where is the cooling fan relay located on a 94 Chevy Beretta 3.1?
It is located at the rear of the engine compartment behind the right strut tower. Thyere are 3 or 4 relays there in a cluster. The one you want has 4 wires: 2- RED 1- LIGHT BLUE and 1- DARK GREEN.
Both of the RED wires are HOT at all times. They come from fusible link [G] located at the starter solenoid (RUST colored).
The LIGHT BLUE wire goes to the cooling fan. This one should be hot whenever the Powertrain Control Module (PCM) turns the relay on. One of the RED wires provides battery positive voltage to the LIGHT BLUE wire when the PCM grounds the relay primary (coil) circuit to operate the relay.
The DARK GREEN wire is the relay control circuit from the PCM. One of the RED wires feeds battery positive voltage to the relay coil and the PCM controls the relay by providing GROUND for the relay coil. The DARK GREEN wire goes to Connector #2, PIN #2 at the PCM.
May 12, 2012 | 1994 Chevrolet Beretta
How to install the conection wires on a central unit
Hello, if you are refering to tne outdoor unit you will have 3 wire coming from a flexible pipe and they shoyld be red, black, and green. The green connects to a ground screw inside the cabinet and the red and black connect to the line side of the contactor coil, does not matter which one goes where because they are equall legs of power. Then you will have 2 thermostat wires and they connect to the side terminals on the contactor coil and again it does it matter what side each wire goes to. Let me know if you have any more questions
Jul 09, 2011 | Coleman Heating & Cooling
Hi, i have a denso cdi no. 32900-19b20 for atv suzuki quadrunner i dont know where each wire goes to. there are 5 wires orenge,black/white,green,black,white/blue please help me. t.y
this particular year was very unusual because it removed the multiple inputs from magnetos and just went with a single (2 wire) signal coil (green, black) which will ultimatly go into the left side case behind the pull start. the white/blue wire goes directly to the coil. the orange wire goes to the ignition and will have 12 volts when the ignition is powered on, then go to ground with ignition off. the black/white is constant ground. this year was different because the cdi let the regulator do all the converting from ac to dc. it is also one of the haardest years to find a box for used.
Apr 13, 2011 | Suzuki RM-Z 250 Motorcycles
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
