Question about ProMariner Pronautic 1250 C3 Digital 12V 50 Amp 3 Bank 63550 ()
Can the ProMariner Pronautic 1250 C3 Digital 12V 50 Amp 3 Bank 63550 charger charge 2 12v batteries in series (24v) and the 12v engine battery? Or do I need a 24v charger.
I'm looking at buying a onboard charger for my boat. I have 2 12v batteries hooked in series (24v) for the trolling motor, and a 12v engine battery. Will this charger work?, or do I need to buy a 24v charger?
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
Mobility scooter battery serial connection charger question
if the charger is a 12-14 v charger you would have to charge 1 of the batteries at the time. connecting both in parallel during charging would cause a short. and in series (the way you have them wired) would provide too low a voltage for the batteries (6-7v each)
if the charger is 24-28v charger you would connect to the wires going from the batteries to the controls/motors (not the connection between the batteries) this will provide each of the batteries 12-14v charge
Mar 05, 2014 | Health & Beauty
Solar Charge Controller should be giving 5amps but only getting 1.5 amps. Please assist
The charge controller is not designed to absorb power it is normally an on or off situation. (sometimes at high speed).
If it was absorbing 3.5A it would go on fire.
I would suggest checking the solar array by shorting it while out of circuit this will determine the mpp current of the array within about 3% at a given time, reconect the array back on to the charge regulator (assuming the sun has not suddenly been covered by a cloud).
If the current is dramaticaly lower than the short circuit current then the battery bank may be controlling the amperage volume, If this is the case there may be a number of reasons for this which would require further info.
Sep 19, 2013 | HQRP 10A Solar Charge Power Controller /...
Changing battery or is it batteries
lots of questions how old is chair, how old is batteries, it has 2 by the way 12v connected in series giving 24v , always change both not just one, check for loose connections first and be sure charger is good try on another chair and/or try another charger on yours if possible they are 95% interchangeable
Nov 29, 2012 | Jet 3 Ultra Power Chair
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
Unit will charge for an hour then all of the lights on the unit blink one at a time in a rapid fashion, this unit is only 6 months old!!!
You either had a lot of exposure to moisture at some time or you did not,. If you did not then get a new unit on your guarantee.
Aug 13, 2010 | ProMariner Prosport 20 Plus Gen 2 Heavy...
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Battery won't charge, 24v charger doesn't light up
Original battery is 130$+, or you can buy replacement for cheapest price (work the same). So, depends from the wallet, choose one... I found them on amazon, take a look:
1. cheapest one (about 30-40$): Amazon com 12N9 4B1 battery
2. Original one (130$+): Finally charging for our multi device world
I hope this was helpful. cheers
Apr 25, 2009 | Garden
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
ProMariner Pronautic 1250 C3 Digital 12V 50 Amp 3 Bank 63550 () Logo
Top ProMariner Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a ProMariner Boating Expert? Answer questions, earn points and help others
