Question about Whirlpool Refrigerators
Whirlpool GD5RVAXVY05 dispensing problem
I have a Whirlpool Gold Refrigerator Model GD5RVAXVY05. Yesterday after a big freeze up around the ice bucket, the auger no-longer seems powerful enough to push ice out. [NOTE: After a freeze-up (ice accumulates under ice bucket and all in ice chute), I always defrost and clean the ice bucket and chute.] When the bucket is not in the door, the drive shaft spins fine. When no ice is in the bucket, the auger and blades spin normally. I then put 5-10 pieces of ice in it and it now has a hard time with it. Could it be a problem in the blades or auger that is the problem or is the auger motor going out? Tried Solutions: Cleaning and defrosting ice bucket Removal and cleaning of drive shaft
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Yep replace the motor and she is back to normal
Posted on Mar 22, 2014
  • Zach Glenn
    Zach Glenn Mar 28, 2014
    The new motor didn't fix the problem. The auger gets stuck on ice. Any other ideas?
  • Zach Glenn
    Zach Glenn Mar 29, 2014
    Here is a video of the problem:http://youtu.be/wePKE8djHv0
dididsaythat
  • 291 Answers
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Posted on Sep 08, 2007
Sea Breeze
  • 4654 Answers
SOURCE: water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Posted on Oct 28, 2007
  • 31 Answers
SOURCE: ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Posted on Mar 13, 2009
Greg20
  • 149 Answers
SOURCE: GE Model TFX20JRBAWW auger freezes up and no ice
there is a anti-freeze kit available. u will have to completely dry the motor first. (if you hold it long enough the heat will build up in the motor and thaw itself)but will freeze right back.
Posted on Jun 12, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
Posted on Aug 30, 2009
What would cause both the water and ice dispenser to stop working?
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 07, 2017 | Whirlpool Gold GI5FVAXVB 25 Bottom Mount...
My ice maker quit, was replaced with a new one, it filled and dumped one time, filled again, didn't dump, was thawed out then didn't fill at all. Water still dispenses from the door just fine.
If the unit is new return it for another one - if there is water in the tray and it is not dumping, either the unit is not working properly or the internal freezer temperature is not going down low enough for the unit to work. Has to go down to at least 10 degrees for the tray thermostat to start the ice dump/making cycle.
Nov 28, 2013 | Whirlpool Refrigerators
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
161 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
