Question about Brookstone 431445 Iron
Need manual for brookstone travel steamer iron 431445
Need manual for Brookstone 2-in-1 Travel Steamer Iron, sku 431445.
Why my Rowanta pressure iron & steamer ....stop putting out steam when I iron.
google ,make model,manual perhaps you will find one
Mar 21, 2015 | Irons
OMNI STEAMER GENIUS 2000 STEAM IRON HAS STOPPED
check the connection. Most probable the heater connections are rusted due to water seepage or melted due to overheating.. If you can dismantle and check the connection.
Jun 09, 2010 | Irons
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
Everything works except steamer
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 30, 2009 | Travel Steam Iron EasyGo Steam Iron Iron
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Wonder Steamer
Have lost the cord & instruction booklet for the Wonder Steamer.. Can you help?
Feb 20, 2008 | As Seen On TV Wonder Steamer Kit Iron
Brookstone 431445 Iron Logo
106 people viewed this question
Top Brookstone Irons Experts
Are you a Brookstone Iron Expert? Answer questions, earn points and help others
