Question about Pantech Cell Phones
Power button on my phone won't work
The power button will not turn the phone off, or I can't lock the phone using the power key. The phone also will not turned on unless connected to the charger.
  • 32 Answers
I think your power button is broken
Posted on Mar 28, 2014
shah92
  • 74 Answers
SOURCE: phone cant be turned on
it is problum from power switch replace it.
Posted on Mar 26, 2007
SOURCE: phone will not turn on unless it's plugged in
The battery has a short in it and if you replace it The phone should probubly work.
Posted on Mar 22, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: my nokia 6300 phone will not turn on.
That means power on button is bad and you need to take it to a technician to fix it for you.
GOODLUCK
Posted on Jan 07, 2010
gwurzinger
  • 92 Answers
SOURCE: my phone doent power on without its charger connected
It is time to get a new battery for your phone.
Posted on Jun 11, 2010
Ammu9966
  • 410 Answers
SOURCE: Phone won't turn on unless connected to charger
Make sure your battry is working properly oherwise change your battery.......
Posted on Oct 18, 2010
My lock button and screen won't work
Please try Hard Resetting and check if it works.To reset, you can refer to the following method, which can reset the phone and erase all the user personal information.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.2)When display press the Menu key at the bottom of the screen;3) Choose "Wipe data/factory reset" through volume key4) Press "Camera" key to confirm the above item5) Choose "YES...delete all user data"6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Jan 04, 2013 | ZTE Score
Lenovo P650WG Phone Won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | Cell Phones
What is emergency calls
YES you can unlock it yourself but unfortunately you will have to reset it and lose all your apps/pics etc.
1. switch off. Hold volume UP and power button and home button simultaneously. release home button (and press again) while still holding volume up and power button. A boot up screen will pop up. Use volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked. Get another phone to call your phone. as soon as you swipe answer press back key (arrow key) (you gotta be quick) and the main home screen will come up!!! . press the left menu button and select settings and turn off pattern code then go to menu and factory reset the phone again.
It worked for me ,.. hope it works for you too
Apr 17, 2012 | Samsung Galaxy Y
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
I changed the key batteries for my 1999 BMW 323i after they died. Afterwards the remote unlock and lock won't work, the car also won't start but it can turn over/on and the radio and the lights...
stick the key in the ignition, turn it to the on position, remove it within 5 seconds, then hold the unlock button down and press the lock button 3 times within 10 seconds and release both buttons. The doors should lock/unlock to give you confirmation and your key should work.
Jul 05, 2011 | 1999 BMW 323 Series
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
My new nokia e52 phone is in lock mode right now. could you please help me to unclock my mobile phone?
try this one... hold the following buttons * (star key),3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons...if not works try this *#7370# then enter locked code..the default code is 12345..thanks ,i hope it will help
Jun 12, 2010 | Nokia E52 Smartphone
My e815 keypad seems dead - power button is the only one working
Well, the phone is done with.
I dont understand why but most "motos"
are like that.
Sorry I couldn't help much...
Jun 26, 2009 | Motorola Mobility E815
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Cell Phones Logo
124 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
