Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
E3 trouble code
I have an amana NFW7200TW-11 washer that during any rinse or spin cycle i get with any type of load i get E3 (weak motor?) checking the motor as described here there is no id on any of the connectors, I did find the red, white and blue wires on a connector the were larger than the rest that had to be to the motor, they checked at 3.0, 3.2, 3.5 would that little difference mean the motor is bad or on its way out?
    Top Expert:
  • Amana Master
  • 22,715 Answers
E3 Error: Machine control is attempting to drive the motor but is not seeing any tacho response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Posted on Mar 22, 2014
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Amana front loader washer Model#
It means there is a problem with electronics, Amana indications are to call the service
Posted on May 31, 2008
vickygomar
  • 460 Answers
SOURCE: Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
Posted on May 08, 2009
richroth
  • 9472 Answers
SOURCE: 3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Posted on Oct 18, 2012
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Amana front load washer error E3
https://www.youtube.com/watch?v=fx7Lrj7gEy4
Jul 06, 2015 | Amana NFW7200TW 27-in. Washer Front...
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
Amana front load load washer locked mid cycle won't unlock or run a cycle
There is a way to enter service mode by pressing a combination of keys on the front panel. This can be done at any time during any cycle. Once in service mode you can input a code to unlock the door.
The exact key press sequence varies by model. For example on the model NFW7200TW you press and hold simulatneously the chime and extra rinse keys for 3 seconds to enter service mode. Can you post your model number please?
Oct 29, 2013 | Washing Machines
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have a NFW7200TW Amana Washer. The problem is my wife said she saw a E3 error and then a nd error. I fixed the pump for the nd error but I don't know what the E3 error is. When I tried to run th
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). Replace the hall sensor.
The "hall" sensor is an internal circuit of the motor. It "tells" the machine control board, what the motor is doing, it's similar to a tachometer on the dashboard of a car. In your case, you want to do the resistance checks on the wires of the CN9 and CN8 connectors at the main control board in the front of the washer (it's easier and more indicative). Unplug the CN9 connector from the control board(red, white and blue wires) testing the pins inside the wire harness connector: from pin#1 /blue to pin#2 /white you should read 3 ohms resistance from pin#1 blue to pin#3/red, you should read 3 ohms resistance. from pin#2/white to pin#3/red, you should read 3 ohms resaistance. That will tell us the motor windings are damaged or not. At the CN8 connector, unplug the connector from the control board and insert the meter probes into the end of the wire harness connector; pin#4/orange to all other pins in the connector should have infinite resistance. pin#3/blue to pin#1/pink should have 4.7 ohms resistance. If you have these resistances, the motor and wiring are OK and you'll need the control board. If the resistances are not within 10% of the ones listed, you'll need to check the wiring harnesses and connections from the control board to the motor, and replace the motor if all checks OK.
Oct 17, 2012 | Amana Washing Machines
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
NFW7200TW washer won't engage spin cycle
We had the same problem with the same model machine and solved it.
Our machine was a month old and started getting stuck at minute 8, so we arranged service calls through Amana customer service. Long story short, the first three service reps couldn't figure out the problem. Two of them called Amana's in-house tech support line and the Amana techs didn't know what the problem was. The fourth repairman was smarter than his predecessors. He called the Amana in-house tech line, spoke to a rep who didn't know what was wrong, and then called in again. He explained that. based on his experience, some in-house techs knew more than others. That turned out to be the case because on his next call-in to Amana, that rep knew exactly what the problem was and recommended replacing the main computer board module. The repair guy ordered and installed the part. The machine has been working perfectly for a month.
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
349 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
