Question about Whirlpool Washing Machines
Whirlpool Washer W10252716 only works when cold water is selected.
MOD WFW 9050XW00 Ser # HL03301086 Type 832-A
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
  • 1894 Answers
SOURCE: washer will fill and run
Could be a bad motor, or something stuck in between the tubs, like a nail, wash cloth, sock.
Try to turn the belt both ways with no power on, unplug the machine, before you start. Take the Belt off, then turn the motor pulley , then turn the transmission both ways. All should turn freely.
On this model i believe you can just tilt the machine back to do all this.
Posted on Mar 15, 2008
  • 409 Answers
SOURCE: My washer will stop after
hi there,
are there any error codes that come up on the display?
Posted on Sep 26, 2008
  • 409 Answers
SOURCE: grinding noise when washer starts
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Posted on Oct 11, 2008
  • 151 Answers
SOURCE: washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Posted on May 03, 2009
RE Whirlpool Mod WTW8200YW0 top load, there is always soap left on clothes in the washer no matter type and amount of detergent my wife uses. Any ideas?
Check the water suppl lines to make sure they are not hooked up backwards the rinse cycle uses cold water if the temperature sensor detects hot water it will stop power to the log valve if hooked up correctly then place unit in a rinse cycle to see if rinse valve is opening
Jan 26, 2015 | Whirlpool Washing Machines
I need a user manual for my Whirlpool Duet Steam Washer, Model # WFW 9500 TW 01.
You can go to www.whirlpool.com and select Owners Center, then select Manuals and Literature. Put in the model no. and you should find one there. Click HERE for this manual.
Hope this is what you need, Please rate and comment Thank You Joe
Sep 07, 2011 | Whirlpool Washing Machines
How old is my whirlpool washer mod-lsq8243hq0, ser-cj2671399
10-12 years old.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How can I disconnect the auto temp control on a whirlpool washer so my wife can wash with straight hot water?
There are no short cuts to auto temp control.To bypass you would need to change the wiring harness and control panel to mod to a lower end washer.
To do that would cost big bucks.
Jan 20, 2010 | Whirlpool Washing Machines
I HAVE A WHIRLPOOL DUET STEAM MODEL WFW 9600 TAOO. NO WASH CYCLES WILL START. I GET A FLASHING 'SUD' AND THEN CODE F 35. DO YOU KNOW WHAT THE PROBLEM IS? WHAT PART NUMBER DO I NEED? WHERE CAN I FIND IT?...
SUD, usually caused by using the wrong type of soap. Your soap should have the letters "HE" on front of box/bottle. SUD can also be a bad drain pump, question is, does it still have water showing in tub?
F35, is a pressure sensor # W10156252, good luck finding it, as Whirlpool has problem keeping these things in stock. They list price at $112.82. Only takes about 20 minutes to change. Research sears.com, select PARTS Direct, enter model number, click on cabinet parts, find analog pressuer switch, see if they have in stock. Or, research the net for someone that does.
Take top of washer lid off, pressure switch is located on top right rear side wall of machine.
Good luck.
Oct 01, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
