Question about Konica Minolta Bizhub Press C6000 Copier
Controller not connected
I powered down my machine to see what the plug looked like. I'm moving to a new location. I powered back up and I get an error saying "controller not connected"
    Habit-Forming:
  • 72 Answers
It might be the sequence you powered up. Turnoff the main power switch in the body amd the controller power. Restart the controller, this will take a few minutes, then restart the printer. Also check cables between the controler and the printer.
If you have Vcare (the service the communicates various conditions and usage data to KM), then unplug that cable, you might need your service tech to reset something. Your printer will work without the connection
Hope this helps
Posted on Mar 23, 2014
Rascal 245. wont work. new batteries. i wired srtraight and motor works. power going to the box under seat but not out
The motor controller may be bad. If the battery charger is connected to the charge port , the scooter won't move even if the charger is not plugged into the wall.
Aug 22, 2016 | Health & Beauty
Sharp mx-2300n copier will not power on after move.
could be anything maybe a strap holding the machine damaged a connector or plug on a board came loose, have a tech come out and look at it
Feb 24, 2015 | Sharp MX-2300N Color Copier
The needle isnt working but the belt is I have a myer victor sewing machine model 668 any ideas as to why
Make sure that:
- the machine is plugged to power
- foot control is connected
- bobbin winder is not engaged
- presser foot is in down position
- bobbin area is clean and free of thread (not jammed with thread)
- re-thread machine and it should work.
Which make and model of machine are you working on?
Oct 13, 2014 | Sewing Machines
Want to connect my c2020 to a new network
First decide whether your going to use the LAN hard wired or wi_fi wireless. Then locate the ip-adress of the new network the name of the domain. or ssid of the new modem or net work example:att who ever is in charge of the adminstration rights to the new network. plug the machine into the router if its dhcp the router will take from there. on the machine go into additional functions<network settings<ip address. with the ip address of the new network you will clear the old and replace the new,example192.168.1.1. if you have a smart phone it will help you find these necessary numbers to plug in. or go to browser and type in http://192.168.1.254 this will get you to the router or modem. it will display a data page with a lot of numbers. you will need its password and its on the modem/router back or bottom. then look for devices on the network you should see the machine look at the ip the router/modem gave it. write it down match the machine with same number and hit print 192.168.1.254 will let you send test page. or call a IT man.
Mar 04, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Sewing machine is sewing slow
This could be for several reasons. I would try the easiest "fixes" first, such as: remove the needle plate and bobbin cover plate, and clean all lint from these areas, including between the feed dog teeth. Lint can quickly accumulate and bog the feed dogs from advancing correctly; oil all moving parts of your machine after removing the top covers, side covers, and the needle plate & bobbin cover plate as mentioned previously--oil anywhere in which metal moves against metal, but make sure you remove all lint or dried oil gunk first; check the belt of your machine to see if it is too tight if it was recently replaced--if it hasn't been replaced or adjusted in a long time, it would more than likely be too loose rather than too tight, but if too tight, it will bog the motor down by making the motor pulley too hard to turn; slowly turn the machine's hand wheel by hand without power with all of the covers off as previously stated and watch everywhere the machine moves--see if anything looks bent, is hitting something it shouldn't or making clanking or clacking noises somewhere as a part may be bent and rubbing somewhere, slowing-down the machine (and of course, if you know the machine has been dropped or damaged, something bent is highly likely which may require a repair tech); check your foot controller--is there something physically blocking the pedal from depressing completely?--these controllers also sometimes just need replaced, so as a test, you may borrow one to test on your machine and see if that helps; if your machine has a fast and slow sewing speed, make sure that setting is not governing the machine from sewing fast; check all of your power cords, plugs, and controller connections to make sure everything is plugged in securely, and maybe try your power plug in another outlet; and lastly, it could be your motor--the motor may need new brushes, some motors require a drop of oil now and then for the bearings (your manual should tell you this if so), or the commutator may have a common build-up of carbon residue that can be removed, and you may have just worn-out your motor that can be replaced. And as always, make sure you are using a new needle after encountering and hopefully fixing an issue.
Feb 17, 2013 | Singer 2263 Mechanical Sewing Machine
After moving washer to a new location, it wont run a normal cycle. It starts to fill up with water and then stops and then it starts flashing F-25, 26, or 28. What exactly does this mean and what can we do...
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Nov 25, 2010 | Kenmore HE2 Plus Front Load Washer
My duet front loading washer has a code 06. When I turn off and unplugged for 1 min. then tried to start it again, it started filling with water then stopped and started beeping the code again. I did this...
This is a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Make sure the wash load is not too heavy and do not move the washer when it is powered on.
If the error persists then the normal process is to check the following:
  1. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
  2. Check the Drive Motor.
  3. Check the MCU
  4. Check the Wire Harness
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps going F1, as soon as I start it. Then I have to open it move the tub around start it again. It does it about 2 or 3 times then again during the rinse cycle
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%5
Sep 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi,we have aBeko WMA 1512 Eco case washing machine,it is coming up for 2yrs old. It will take on water and the control switche moves as required to empty, but drum does not move,it's like it goes through...
I suggest the next step is to check the motor brushes. Take belt off and undo bolt at right hand side of motor .Allow motor to pivot down and then pull to remove. Brushes are located at back of motor in plastic housings. If worn down to housing they will need replacing. Any problems dont hesitate to ask.
Nov 16, 2008 | Washing Machines
Door Won't Lock water in machine
do you hear a small clicking noise? if so remove top coner 3 screws in back..on back wall at top edge plastic box with wires is main control bd try moving connectors up and down as you press start button if door locks and machine works bad connection on inside of control replace control or cheap fix try shimming connector in postion where it will work may last a bit longer(belive connectors are green plugs)
Jun 17, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Konica Minolta Bizhub Press C6000 Copier Logo
274 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
