I don't know how to set the time and date on my digital multi clock GH120A, I do not have the instructions, could you help?
I am unable to set the time and date on my multi digital clock GH120A, I don't have the instructions as this was given to me by my friend, could you help?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
Check the knobs and try one by one you will succeed
Posted on Mar 23, 2014
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
Jan 03, 2010 | Watches
Sony NWZ-E438F clock display is blank..
To set date and clock:
1. Go to Settings (looks like a suitcase-bag)
2. Go to Common Settings
3. Go to Set Date-Time (this allows you to set the date and time)
If you want to change date and time display format, you can also do this under common settings.
I hope this helped
May 28, 2009 | Sony NWZ-E438F Digital Media Player
Wrong time
To set the time do the following:
Setting the date and time
Press the Back/Options button ((the left pointing green arrow)).
You may need to do this more than once until the main menu appears.
Select Extras Date & Time. The current date and time are displayed.
Press and hold the Back/Options button.
Select Set Time or Set Date to change the time or date settings.
Select Date Separator, Date Format and Time Format to adjust how the date and time are displayed.
Select the options you want.
Mar 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
Clock
Did you read your instructions?
When entering the date or time if the digit is single a zero must be entered first!
- press menu/select in idel mode
- press V/^ until you reach date/tem then menu/select
- use keypad for year then menu/select
- set date eg 0109 , press menu/select
-set time e.g 0730 and ^/v for am/pm then menu/select
- screen should display STORED
Jan 10, 2009 | Vtech Cordless 6041 Phone
Install setting for Clock and Calendar
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
Your Owners manual
Setting the date
The calender display adjusted in this mode appears
when the telephone source is selected
or sources and the feature demo are off.
1 Use MULTI-CONTROL to select
Calendar.
2 Push MULTI-CONTROL left or right to
select the segment of the calendar display
you wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the calendar display:
Day—Month—Year
As you select segments of the calendar display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the date.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
select the segment of the clock display you
wish to set.
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Jan 01, 2009 | Pioneer DEH-P7900BT CD Player
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
Oct 07, 2008 | Audio Players & Recorders
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
