Question about Teac AG-980 4 Channels Receiver
Not switching on!
I heard a small bang when I switched my TEAC AG-980 on and now it will not switch on. The standby light is on which rules out the fuse. When I press standby either on the remote or on the unit itself it appears to switch on (display shows either AUX or TUNER) but then immediately goes back into standby after 2 seconds. Any odeas what is wrong?
  • 41 Answers
A short has transpired before the fuse. Now in protect mode. See a tech.
Posted on Apr 05, 2014
jack_daniels
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
  • 22 Answers
SOURCE: Teac Code for a cox universal remote to control a AG-D9260 AMP/Receiver
Try code: 2130
Posted on Mar 31, 2009
SOURCE: TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
Posted on May 08, 2009
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
SOURCE: Teac AG-L800 clicking problem
screen can see proctet
Posted on Dec 12, 2010
I have a Teac AG-780 Reciever. I've lost the Remore and I can't switch to Phono mood.
Remotes.com has an original remote and a substitute replacement remote: http://www.remotes.com/SearchResults.asp?Search=ag780 . However, if the Phono button on the AG-780 does not switch the receiver into Phono mode, you may have an additional problem that needs to be fixed. I'd recommend that you check the wiring, including the Phono Ground wire, and make sure that the turn table actually works. If you have your turntable connected to one of the other inputs, the Phono ground may not be recognized.
I hope this helps.
Jan 18, 2016 | Teac Audio Players & Recorders
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
How can u tell if your internal speakers are blowed?
Hi Patricia,
You may need a professional cleaning of all the switches internally. If you are up to it. Compressed air with an electronic aerosol cleaning solution is the first approach. Over time these parts develop oxidation. The voltage levels are small and the signal cannot be generated.You need to know what too clean, most are visible. You can also look for internal fuse protection. Make sure when the cover is removed to pull the power first. Some higher end Amplifiers provide protection. You will need a digital multi-meter or equivalent to test the fuses.
http://www.teac-audio.eu/downloads/2/2/8/1/9/TEAC_AG-790E_datasheet_EN.pdf
So before doing all of that. There is a reset switch. It is located between the speaker switches on the face of the receiver. At the top and in the middle left center of the display. Not at the speaker buttons on the left.
That function may be tripped. Reset it twice and try testing with different speakers if it fails again. It may trip instantaneously if there are abnormal voltage levels present in the circuit that arouse protection.
I have located and offer you the Manual PDF. Go here first and try the following. On page 8 in the manual. Titled, " Name of each Control" (D). There is a location diagram for you to observe. Please take some time and look this over.
http://www.teac.com/content/downloads/products/746/ag-790_6l_manual.pdf
Finally, if you need someone to talk too. The You Tube Video has an outlet store tied to it that offers live help.
TEAC AG 790A AM FM Stereo Receiver
Good troubleshooters always take a problem apart one step at time. So go for it. I know you can do it. Fare. Well.
Jun 20, 2014 | Teac AG-790 Receiver
Will not switch on
Probably an electrolytic capacitor blew... should be obvious if you remove the case. The tops blow off or split... may leave residue.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
Teac AG v6200 wont stay on
Check your speaker wires, if they are crossed somewhere then the system protects it's self.
Jun 22, 2009 | Teac Audio Players & Recorders
i have this problem and it is a starter relay that is faulty , part number JQX-115F
i think this is a pro job to repair though
Mar 22, 2009 | Teac AG-L800 Receiver
Teac AG-D8900 Receiver - No power
Hello meml,
Since you mention that there is no standby light at all, the problem could be related to the receiver's main power supply, which is not uncommon for a unit of this age.
Now, if you decide to take the unit to a repair shop, do not let the cost of repairing the unit be the only factor that determines if you bring it back to life or to use it as a door stop.
Consider the replacement cost compared to the repair cost, also, have in mind that newer receivers can supply more output power per channel and have more advanced decoding technologies among other features. Hope this helps your decision. Let me know.
cancerags.
Apr 11, 2007 | Teac AG-D8900 Receiver
Teac AG-980 4 Channels Receiver Logo
173 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
