Question about RCA D52W23 52" HDTV CRT TV
I have a 53inch RCA big screen tv, we have double vision
I have a 53inch RCA big screen tv, we turned it on and now for some reason we are getting double vision ... everything else works fine.. just getting Double vision, can i fix and can i fix it myself ? RCA model # D52W23, Serial # G023CN026.
  • RCA Master
  • 8,617 Answers
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Posted on Jun 14, 2009
It not there
Posted on Mar 09, 2012
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if...
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Issues with the big screen
This is essentially a convergence problem and will continue to get worse. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted on your progress.
Dan
Jul 14, 2008 | RCA Scenium HD65W20 65" Rear Projection...
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
Big screen TV
chances are the repair man wanted to sell you a whole board because with mitsubishis this problem is amost always the convergence ic's also in that model very seldom the resistors burn out in that unit its almost always the IC's that do that. I looked for you information you have an old chassis but I think its similar to the Vz2 I believe you need IC number STK391-020 thats based on theVz2 chassis but pls double check and you need 2 of them you can also save yourself if you know how to solder a lot of money by replacing them yourself its about a 45min job if I can help you any further pls let me know or if you would like a link where you can buy your parts very reasonable with tech online support let me know
May 08, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
520 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
