Question about Whirlpool Furniture
How hard is it to add freon to a wine cooler?
I had a service tech out and he wanted 300 dollars to recharge my wine cooler with Freon. Can I do this myself?
    Problem Solver:
  • 13 Answers
Don't attempt it, need special equipment, seek additional quotes but if it's leaking them there is a gas loss issue. You should never need to add gas to a fridge that is sealed in the factory.
Askntechnician why it needs a gas top up? It must be leaking from the pipe work. Adding gas wont solve the problem, you need to find the sauce of the leak to remedy the problem longer term.
Posted on Apr 29, 2014
  • Michael Apr 29, 2014
    Should have read the source of the problem cheers
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
pride applia
  • 232 Answers
SOURCE: Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Posted on Dec 31, 2009
SOURCE: E3 error message on Magic Chef wine cooler
Taken from another poster at Home Depot reviews and similiar to what others have found...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Posted on Feb 08, 2010
  • 1070 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
SOURCE: Unit was leaking at rear coil, sealed the leak but know it needs freon. Can it be added?
You will need a inline piercing Valve similar to one of these:
http://www.enalt.com/pdf/cdz/componenti/Valvole%20Perforatrici.pdf
This will give you the service port you need to access the freon line
Posted on Oct 19, 2011
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
WAS TOLD TO TRASH VCWB300 WINE COOLER BECAUSE OF FREON LEAK VERY SUSPICIOUS
Do you know what type of freon it is? And how old of a unit is it? Why was the service technician initially called?
Mar 17, 2013 | Viking VCWB300R Wine Cooler
I have a frigidare #PLKU1267DSO kegbox. the compressor runs and gets hot but the box will not cet cold at all. the coils inside also have rust on them
Your keg box runs very similar to a Wine Cooler. I believe this can help you. The pressure for the freon and the steps for trouble shooting is he same. Give it a try.
Danby Wine Cooler Repair Recharging your wine Cooler with 134a Freon
Feb 19, 2012 | Refrigerators
How do you add freon?
adding freon is not the answer unless you can prove you have lost some. The unit is hermetically sealed so should not lose freon unless you have punctured the system and the gas has escaped. you will probably need a fridge expert to test and check over the system.
May 17, 2010 | Haier BC112G Wine Cooler
A layer of ice forms on the unit. Checked & replaced thermostat
here's the deal. unless you have a license to purchase freon you can't. Most likely the unit contains r-22 freon unless it was made before I think 1987 if made before then it is more than likely r-12. The reason appliance techs do not want to do this is because of the intensive set up in orderto access the system to add freon. they have to weld connections to access the freon and in such small areas it can be a massive pain. I would contact Whisper cool and see if they have any service centers in the area where you can take the machine for repairs.
Good luck hope this helped
Dave
Jan 14, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
All fridges, freezers, coolers, etc need access ports added to them before any refrigerant can be added to them. Makes you wonder how they do that eh?
May 29, 2009 | Avanti WC54 Wine Cooler
Furniture Logo
204 people viewed this question
Top Whirlpool Furniture Experts
john h
Gil Shultz
Are you a Whirlpool Furniture Expert? Answer questions, earn points and help others
