Question about Yamaha RX-V675
Cant get volume with the iphone application
The volume icon (speaker) on the remote has a line thru it (off) It is supposed to toggle on or off but wont work. Ideas?
2 Suggested Answers
  • 85 Answers
SOURCE: RECEIVER WORKS FINE WITH THE RADIO NOT THE TV.
correctly connected to output on tv ? ie red and white left and white and not yellow (video)??
Posted on Jan 19, 2009
How do I unlock the screen rotation
if you use iOS 7 or 8, swipe up from the bottom to bring up the menu. ON the top row of icons, on the farthest right there is an icon with a lock surrounded by a circular line and arrow. Tap this to toggle the rotation lock on and off.
Feb 24, 2015 | Apple iPhone 5c
The volume on my iphone 5 is not working
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
Apr 08, 2014 | Apple iPhone 5
Wd3200h1u00 cant mount
If the hard drive cannot mount, there is not a valid volume on it. With the drive physically connected and powered, open Applications/Utilities/Disk Utility (or if the hard drive in question is supposed to be your OS volume, boot up to Disk 1 of the OS install set and open Disk Utility from the File or Apple menu (I don't recall which one at the moment). If the disk icon shows up in the list of available disks, click on it. Any volumes on the disk should appear. If not, the disk is unformatted or the volume information is corrupted. If the icon doesn't show up at all, the disk is either not properly connected and powered or is defective.
Jun 20, 2013 | Computers & Internet
Well i am trying to figure out how the **** an i suppose to volume up this grey little speakers???
if you are referring on volume loudness
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
hope this helps you
Jul 18, 2011 | Polk Audio AMR50 Computer Speakers
I bought iphone4 in japan then i open line here in the philippines but i cant use the internet on my phone how am i supposed to do so i can dpwnload some applications from my iphone 4
you can use internet connection thru wi-fi or GPRS.
GPRS needs to be activated and the configuration settings must be save to your phone.
like for globe : the provider will send you the configuration settings and ask you to save.
pin code is 1234
if you want some application and games (libre ko na po sa inyo ito)
* be sure you have itunes installed on your pc or laptop,
* iphone usb cable
* itunes account (set and authorized this pc on the menu bar)(optional)
pakikalabit lang po ito ... CLICK ME
hope it helps.... please rate my solution.... thanks...
Jun 05, 2011 | Computers & Internet
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
How can i increase volume for mic iphone 3gs or input volume during calls..they cant hear me clearly..thats my phone problem..iphone 3gs..
Hello
1 .You need to confirm if its the volume or the mic of your phone that has the problem.
2 .If its the mic,your callers would not hear you but you would be able to hear them.
3. You can Adjust the volume of your iPhone by depressing the volume button on the left edge of the phone, close to the top. This will cause a volume indicator to appear, superimposed over the other icons on your screen. This will increase the volume of your ringer. If you wish to adjust the volume of the phone speaker, use this button during a live phone call. You can also control the volume of your speaker when you are using your iPhone as a music player in the same manner.
4. If its the mic,remove the iPhone from the case, as your case may be blocking the device's microphone.
5. Plug the iPhone device cable into the iPhone and into the computer's USB port.
6.Launch iTunes. Click "iPhone" or the device's name in the sidebar in iTunes and click "Summary then Click "Check for Update" and "Download and Install" to update your iPhone's OS.
7. Remove the device cable after the update finishes and insert your headphone jack into the iPhone's headphones port,tap "Phone" on the home screen, tap "Contacts" and tap a contact to place a call.
8. Press the "+" button on the microphone to increase your microphone's volume.
9. If the problem persists take your iPhone to your local Apple Store for professional service.
BEST OF LUCK
Dec 15, 2010 | Cell Phones
I have a built in mic and the computer says that it can't not find it. I have also checked to make sure that my computer is using the default setting are there any other ideas?
in your computer trey you see a red speaker icon (reltek hd adio sound output)(if cant see read downside).
doble click this icon and you see a sound setting box.
you see upside 5 option(sound effect , mixer , aodio I/O etc.)
choose MIXER and you see two option in upside PLAY BAKE and downside RECORD see upside you see option subwoofer, center line volume . front mic, mic volume and cd volume.
you see that front mic and mic volume is muted.
remove mute and enjoy
(if you cant see icon go to this address:-
My Computer C:\Program Files\Realtek\InstallShield.
in this location you see two red speaker icon.
dobble click the icon "RTHDCPL"and now you see the icon)
Dec 21, 2009 | Computers & Internet
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
Yamaha RX-V675 Logo
16 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
