Question about Wenger DAYTONA II Mouse
Datona II Swissgear just doesn't work, won't connect
Trie the solutions from the other bloggers, doesn't help.
Laurie
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
I have changed the batteris, the mouse shows low battery, usb showing red light, ultimately mouse is not connecting and not working ? what is the solution
hi r_sreedasyam
before your mouse run out of battery, it can still be used?
if it can still be used, try to open the battery cover. positive and negative metal rubbing with sandpaper or any tespen.
re-insert the battery.
(Insert really new)
please call again for more information
thanks and regards
Dec 08, 2010 | AVENUES The SPYDER SwissGear Wireless...
My swissgear Spyder mouse won't work after battery change
Need to press connect button on mouse and the button on usb within seconds of each other to sync the mouse. At least that worked for me when I changed batteries.
Jun 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
Swissgear spyder mouse will not work
Had the same problem with my wife's...you have to push the connect buttons on both the receiver and the mouse almost simultaneously after turning the mouse off and back on. Keep trying, it took me lots of tries.
Jun 07, 2009 | AVENUES The SPYDER SwissGear Wireless...
My red swissgear mouse will not connect to my laptop
I have used allot of different wireless plug and play devices but this by far is the crappiest one by far I am no slouch when it comes to troubleshooting things on my PC but this mouse is junk Problems from day one. My advice is return it before it's too late and buy a different brand. I like the page forward and back right ast my finger tips but the connectivity issues are not worth the hassel
Jun 04, 2009 | AVENUES The SPYDER SwissGear Wireless...
Wenger DAYTONA II Mouse  Logo
159 people viewed this question
Top Wenger Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wenger Computer and Internet Expert? Answer questions, earn points and help others
