Question about Apple iPhone 5
Says cannot make the call try again later when giving a voice command using a headset
Out on the road trying to call home unable to make this call try again later or says cannot make that call try again later
  • d ale dutcher
    d ale dutcher Mar 26, 2014
    i use a parrot headset on the road
  • d ale dutcher
    headset is the Parrot
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
Hi . first try your headset on different i phone if its gonna (work )that's mean you have a board or software problem in your phone i5 & nobody could fix that .
but if its gonna work on other phone that's mean its not the original one what you have & just go directly to apple store & get one (headset) there & try it on the spot in case its not gonna work . it should work .
Posted on Mar 24, 2014
    New Friend:
  • 17 Answers
You might want to restart the device by a hard reset; it shouldn't' take anymore then 1-2 minutes. Hold the power and home button until the phone restarts to show an apple.
Alternativley you can reset your network settings by ->Settings->Reset->Reset Network Settings
Posted on Mar 22, 2014
Unable to make calls using voice commands
Try by reseting your Headset device following this steps.
How do reset the H19txt to factory default
You will need to re pair the Headset with the phone.
Jun 30, 2014 | Motorola Mobility H19txt Universal...
Although headset is paired successfully with phone I cannot use voice dialing commands.
You can try to press and hold the Call button while turning on
the headset to turn these features on/off and select reset to factory default and just follow the voice prompts to make changes to
these settings. Remember that this action erases all pairing information stored in your headset so you will have to paired again.
Jun 29, 2014 | Motorola Mobility H19txt Universal...
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Voice command times out -won't work
If your phone has the voice capability's then you should be able to use it through your headset. If this was a plan you were using before a free app where it could be commanded by voice maybe it is over. However if your headset simply is not working I would try to return it the retail place of purchase if it is still under warranty, if not you can always talk to Plantronics tech at 800-544-4660.
Good luck from Headsets Direct!
Sep 16, 2009 | Plantronics Explorer 330 Headset
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
No voice command on headset.
Control Panel -> Speech -> Speech Recognition
Hope this helps.
Jan 04, 2009 | Plantronics 510 Voyager Headset - PLN-510...
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
VOICE CHAT IN YAHOO MESSENGER 8.1 Using Vista Home Premium
vista has some issues with YIM...check for latest drivers
Mar 20, 2008 | Logitech 250 Headset
Voice commands
The telephone has this feature?
This feature is active?
As you sad it's appear that you use that in another telephone, try to check that.
Nov 20, 2007 | Motorola Mobility H700 Wireless Headset
Apple iPhone 5 Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
