Question about Briggs & Statton Briggs & Stratton Electric Starter 12.5 16 693551 New 33-772
Will not fire off the engine, spark plug cannot be removed from whatever it it connects to
Will not fire off. Spark plug cannot disconnect fron the wiring that it pushes into. it appears that section must be replaced
    Problem Solver:
  • 22 Answers
Spray some wd40 into wiring what spark plug goes into it should pull of
Posted on Apr 13, 2014
New spark plug, cleaned air filter, won't start, used starting fluid, how do I check spark?
unscrew spark plug . plug cap back on and hold it against engine and pull cord. plug should give healthy blue spark. if orange the little elbow contact on bottom of plug should be adjusted by tapping it lightly to close the gap between electrodes. do not hold plug by its body when pulling starter rope or ignition. if u can smell petrol on plug then ur engine is flooded.
Apr 25, 2016 | Garden
I have a early 1970 1600 dual port volkswagen not getting fire to plugs what could be the problem
IF NOT MODIFIED THIS CAR HAS CONTACT BREAKERS (POINTS) Check for ignition at coil (terminal 15). If OK check if coil is grounding by sorting the negative (1). Also sheck for spark at this point by removing HT lead from distributor and holding en close to ground point (engine or body) but not touching. If coil is ok you should get a spark. Then go to the points themselves, Turn engine to point-closed position then open and release the points with a screw driver. You should see a spark there. If not replace points and also check connection wire fron coil.
Apr 26, 2015 | Volkswagen Cars & Trucks
1999 dodge intrepid problems
Usually if you want to check for spark, you remove one spark plug fron the engine. Then with the wire still connected, set the plug's metal base on a ground such as engine block. However with the coil packs that would be difficult to impossible. Second you can be reasonably certain it's not a coil, wire or plug. This leaves you with very few options. I would suggest turning the key on-off-on-off-on in the span of a few seconds, your digital odometer should then display a series of numbers. These are engine fault codes. If your odometer is not digital then your check engine light will flash a certain number of times, count the flashes and write them down to look up in your service manual, or one at the library.
May 03, 2014 | 1999 Dodge Intrepid
1999 chevy blazer wont start turning over but not firing replace distributor cap and rotor any througts on it
first check for spark disconnect any plug wire from the spark plug remove the spark plug from the engine reattach the plug wire and set it on the fender well DO NOT TOUCH THE PLUG OR WIRE AND CRANK THE ENGINE AND SEE IF THERE IS A SPARK BETWEEN THE ELECTRODE AND ARM. if there is no spark you have an ignition problem check for 12v at distributor.
if you have spark then check fuel pressure the fuel pump could be bad.
Apr 28, 2011 | Chevrolet Blazer Cars & Trucks
Describe your how fix my pontiac 2000 montana Problem changing spark plugs
Inspection
Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the left side spark plug wires from the spark plugs.
  3. Remove the left side plug wires from the retaining clips.
  4. Rotate the engine for access as follows:
    1. Set the parking brake.
    2. Shift the transaxle into neutral.
    3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
    4. Install the Engine Tilt Strap J-41131.
    5. Pull on the engine in order to rotate the engine forward.
    6. Tighten the strap.
  5. Remove the right side spark plug wires from the spark plugs.
  6. Remove the plug wires from the retaining clip.
  7. Remove the spark wires from the ignition coils.
  8. Remove the plug wire assembly from the engine.
    NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
To install:
  1. Install the right side plug wires to the ignition coils and then the spark plugs.
  2. Install the spark plug wires to the retaining clip.
  3. Rotate the engine back to the original position.
  4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
  5. Install the spark plug wires to the retaining clips.
3.9L Engine
  2. Remove the intake manifold cover.
  3. Remove the left side spark plug wires as follows:
    1. Disconnect the left side spark plug wires from the spark plugs.
    2. Disconnect the left side spark plug wires from the ignition coil.
    3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
    4. Remove the left side spark plug wire assembly.
  4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
  5. After rotating the engine, remove the right side spark plug wires as follows:
    1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
  6. Remove the right side spark plug wire clip from the ignition coil bracket.
  7. Remove the right side spark plug wire assembly.
To install:
  1. Install the spark plug wire assembly.
  2. Install the right side spark plug wire clip at the ignition coil bracket.
  3. Connect the plug wires to the ignition coil and spark plugs.
  4. If the engine was rotated for access, return the engine to the original position.
  5. The remainder of the installation is the reverse order of removal.
Feb 05, 2011 | 2000 Pontiac Montana
How to change spark plugs in 2.5 misubishi in a 1998 sebring
Remove boot to spark plug using a boot puller. Unscrew spark plugs using a spark plug socket, extension, and ratchet.
Do them one at a time to avoid confusion. Installation is the reverse of the removal.
--- FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason, it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: 2.0L and 2.4L Engines Firing Order: 1-3-4-2 Distributorless Ignition System 90902g01.gif
Fig. 2: 2.5L Engine Firing Order: 1-2-3-4-5-6 Distributor Rotation: Counterclockwise 90902g02.gif
Jul 19, 2010 | 1998 Mitsubishi Galant
A ned positon cables fron distribuidor to
1 8 4 3 6 5 7 2 firing order
Cylinder 1 it the furthest forward in the engine compartment. That bank is drivers side 1 3 5 7 Passenger side is 2 4 6 8
You did mark #1 when you took it apart right?
If not, remove coil wire from distributor and ground. (IMPORTANT ALWAYS GROUND THE COIL SECONDARY LEAD) remove #1 spark plug. Turn engine over by hand. When you hear the whoosh that's #1 compression stroke. Line up timing mark to 0 Degrees. Remove distributor cap. Wherever the rotor is pointing, that is #1 cylinder. Crank engine to determine direction of travel of rotor (clockwise probably) Next cylinder will be #8 next will be #4 next will be #3 next will be #6 etc. just follow listed firing order.
After repair is complete reconnect coil wire.
Sep 28, 2009 | 1992 Chevrolet C/K 3500
Change spark plugs on 2007 Toyota Camry
In servicing the spark plug . If the owner will be the one to change the spark plug then. the owner should locate the spark plugs . then prepare the equipments that is going to be used to change spark plug .First disconnect the spark plug cable to the spark pug . Then use the equipment to take the spark plug off to the engine. The spark plug should be twisted counter clock wise using the equipment to remove the spark plug.Then replace the spark plug.In returning the spark plug ,using the equipment you have to twist the spark plug clock wise . Then set the distributor shaft turn it according to the proper firing order that will be set to the spark plug if it is 1,3,4,2. Then the distributor shaft mark will be on 1.If 2,3,4,1 then the distributor shaft mark will be on 2. Then connect the spark plug cable , after connecting the owner have to test start the car so that to if it back fires .If it back fires then the owner have to repeat again the setting of the firing order of the spark plug until it will not back fires.If the owner don't have time to do the job in servicing or changing spark plug then the owner have to go to a car mechanic and let them change the spark plug.
Sep 26, 2009 | 2007 Toyota Camry
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
I can only find three spark plugs on my freelander v6 engin
Remove
  1. Disconnect battery earth lead.
  2. Remove engine acoustic cover.
  1. RH bank only: Release locking clips and disconnect multiplugs from plug top coils.
  2. RH bank only: Remove 6 bolts securing plug top coils to RH camshaft cover and remove coils.
  1. LH bank only: Noting their fitted positions, disconnect ht leads.
  2. Using a 16 mm plug socket, remove spark plugs from both cylinder heads.
Refit
  1. Set gap of each new spark plug to 1.00 mm .
  2. Fit spark plugs and tighten to 25 Nm (18 lbf.ft) .
  3. LH bank only: Connect ht leads.
  4. RH bank only: Fit plug top coils to spark plugs.
  5. RH bank only: Fit bolts securing plug top coils to RH camshaft cover and tighten to 9 Nm (6.5 lbf.ft) .
  6. RH bank only: Connect multiplugs to plug top coils and secure with locking clips.
  7. Fit engine acoustic cover.
  8. Connect battery earth lead.
Jun 04, 2009 | 2003 Land Rover Freelander
Briggs & Statton Briggs & Stratton Electric Starter 12.5 16 693551 New 33-772 Logo
74 people viewed this question
Top Briggs & Statton Tools & Hardware - Others Experts
Are you a Briggs & Statton Tool and Hardware - Other Expert? Answer questions, earn points and help others
