Question about 4Button Remote 474P
Key fob not working well
Have to push the puttons several times to get car open.Just changed the battery but that doesn't help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Fob my be bad try other fob if that one works replace bad one.
Posted on Apr 30, 2014
2008 Altima with push button start. Why won't the fob unlock doors?
Insert key into and remove it from ignition more than six times in 10 seconds. When the hazards lights will flash twice insert key into ignition and turn to ACC position.
Then push any button on key fob once, the hazard lights will flash twice. Then open drivers door to END.
Should be all working again.
Jun 06, 2015 | 2008 Nissan Altima
I have a 2007 ES 350. Changed key fob battery,now nothing works. Only immobilizer security light is flashing and engine start stop button has amber colored light on
Be sure to use the correct battery, properly in place, clean the key contacts , See owner's manual for additional information.
There are specialized locksmiths for car keys
Oct 02, 2014 | 2007 Lexus ES 350
Intermittant key fob in volkswagon cc
put the key in contact,switch contact on,
push the remote while contact is on,and ket is in
all should work now
if not,
key in door lock,swith to open,while holding in open pos push remote,
Mar 22, 2014 | 2010 Volkswagen CC
My key will not start my car,then it wouldn't open the door
This model year comes equipped with Keyless Enter-N-Go, which uses an electronic transmitter in the key fob to communicate with the car. The vehicle's doors will not unlock and the vehicle will not start if the key fob is not matched to the vehicle or if the commonly-available watch battery in the key fob has been depleted. The EVIC will flash a message upon vehicle startup if it determines that the battery in your key fob is low on charge and should be replaced.
To open the doors, try the following:
1. Use the spare key fob that came with the vehicle. If the battery in your main key fob is depleted, the spare key fob's battery may still retain charge due to its much more occasional use.
2. The key fob comes with an emergency key inside of it. To remove the emergency key, slide the mechanical latch on the back of the key fob sideways with your thumb and then pull the key out with your other hand. This key will allow you to unlock the driver's side door and glove compartment. It will not start the vehicle.
To start the car with a severely-depleted key fob battery, try the following:
1. In case the ignition switch does not change with the push of a button, the RKE transmitter (Key Fob) may have a low or dead battery. In this situation a back-up method can be used to operate the ignition switch. Put the nose side (side opposite of the emergency key) of the Key Fob against the ENGINE START/STOP button and push to operate the ignition switch.
To replace the battery in your key fob, try the following:
1. Remove the emergency key from the key fob following the directions above.
2. Using a vinyl spudger tool or a flat-bladed screwdriver, gently pry the two halves of the key fob apart at the indented slot above the slot for the emergency key.
3. Replace the depleted battery with a new battery. Use the depleted battery to visually match the size. The battery is usually available wherever watch or hearing-aid batteries are sold.
4. Snap the key fob back together and replace the emergency key. If the issue is a depleted battery, your key fob should operate normally.
If the issue is not related to the state of the battery, you will probably need to contact your local dealer for service.
Source: Owner's Manual, pages 12-17
http://justgivemethedamnmanual.com/dodge/dodge-charger-owners-manual/
Mar 01, 2014 | 2011 Dodge Charger
I changed my car battery, now my 2008 Nissan Altima key fob won't work
There is a special procedure involved in keying your fob to your car once the battery has been changed. You must lock and open the door with your key. Turn the ignition to "on"(not start) then push the fob's open and close button, then shut off ignition. This procedure is done everything the key battery is changed. Hope this can help you!
Motorcycle Diagnostic Scanner
Oct 31, 2012 | Cars & Trucks
2009 altima doesn't recognize key all the time
Nissan been having some problem with key FOB, they don't wont to acknowledge it cause it will turn into a RECALL expensive fix for them.
Sep 21, 2012 | 2009 Nissan Altima
My key fob for my 2006 LaCrosse unlocks the doors & opens the trunk, but doesn't lock the doors. Can it be cleaned, or does it need to be replaced?
It is not clear whether the problem is with the fob or the receiver in the car. You could try replacing the fob (they are available online from various sites) but the receiver will need to be programmed to use it, and that usually requires a trip to a dealership (unless you have access to the OEM service manual). Your best bet is to take it to a dealership and have them diagnose and repair the problem.
Jul 05, 2017 | Cars & Trucks
Chrysler crossfire key fob will not work to lock, unlock or panic
Put key ignition press unlock or lock 2 times then turn key to accessory position within 30 seconds. Your FOB should work properly.
Jul 25, 2012 | 2006 Chrysler Crossfire
2008 Mazda 5 key fob battery changed and it still won't work. how do i fix it?
I have taken a GM key FOB apart before and found a bad soldered connection. If that doesn't work, people sell them on Ebay all the time, look up how to program on the web and reprogram it to match your vehicle.
Jan 05, 2012 | Mazda Cars & Trucks
Key fob lights up but doesn't work even with a new battery
I'm more familiar with Range Rovers and Saab's when it comes to key fobs but if you changed the battery you have to re-program the key fob. If you do not have an owner's manual that can take you through the steps you might want to try: push and hold the lock button on the key fob, put it in the driver's side door and turn to lock. With the button still depressed turn back to open, remove the key and release the button. If this doesn't work check any and all fuses associated with your system and last but not least you could take it to a dealer. Good luck!
Aug 25, 2009 | 2000 Renault 181
4Button Remote 474P Logo
181 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
