Question about Tappan MGF500PBW Gas Kitchen Range
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners are match light and work ok. If you need the model number/serial I will need to go to the trailer's storage unit. This is not a hot surface igniter, it is a flame igniter.
    Brigadier General:
  • 3,917 Answers
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Posted on Jun 14, 2009
I have a model 3110PRW gas range and can not get the pilot lights to light. I am getting gas through as I can light all four burners but the pilots will no ignite. It is set up for propane gas.
Hi on the burners there is a hole where the gas comes out of the burner to light off the pilot is this blocked or are the pilots blocked short pilot flame
Feb 09, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven takes up to 15 minutes to light. glow plug does appear to be bright orange immediately after turning oven on. it is a propane unit.
Hi, glow plug (element) should glow red, maybe you got faulty thermocouple, located ot bottom of oven burner, unit where gas enter oven burner, they could either be gas pilot or electrical element as metering device, give a little tap, could be stuck, could also be your thermostat, check oven thermostat, many ways to check oven thermostat, give thermocouple a little tap located at beginning of oven burner, if it didn't work, call a mechnic to make futher checks. good luck.
Aug 05, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Tappan MGF500PBW Gas Kitchen Range Logo
295 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
