Question about Dishwashers
Salt indicator I have a Lamona HJA8630. It indicated low salt , so I filled the chamber. At the end of the cycle everything had a salt coating and a some items were showing signs of rust. Also the low salt indicator was showing. I have now re-filled to container and it is still showing low salt. any ideas
  • 641 Answers
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
  • 1462 Answers
SOURCE: Low salt light
try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Posted on Jun 24, 2008
SOURCE: salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Posted on Sep 08, 2008
stephanos18
  • 144 Answers
SOURCE: dont know where to put the salt and how salt indicator goes off
it should have a dispenser in the bottom of the tub you just need to unscrew the lid
Posted on Mar 27, 2009
The low salt light is on and is not making chlorine. Salt level topped up yesterday as per pool shop sample. Chlorinator stopped sometime yesterday
the salt light indicates more than low salt level. now that you have eliminated that possibility, if the light is still on, there may be several possible causes. the cell may be dirty, or nearing its end of life, there might be restricted water flow or the water is too cold. these are all easy and inexpensive to check
Mar 06, 2016 | Pool & Spa
My generator first indicated low salt. I've added plenty of salt, and it still indicated low salt. I turned it off for 24 hours, and tried it again, now it has the service indicator light on,what next ?
We've found with our saltwater system (which doesn't have a service light, so not the same model as yours) that we have to add far more salt than we expect before the 'low salt' indicator goes off. It also seems to be very tempramental whenever it's been off for a while (such as over winter) & needs to run for very short bursts at first before working up to normal operating times.
Aug 02, 2013 | Intex Automatic Salt Water System for ...
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
This is the second summer for my krystal clear salt water system (above ground intex pool). When the low salt light came on I cleaned the cell as directed but the light came back on. I shut it down and...
Did you check the salt level and was it between 2000 to 3000ppm?? These are the two causes for the low salt alarm.. Dirty scale buildup on the cell and low salt level.. Also, you may need to add a scale buildup preventer. hth makes a bottle called "cell saver" it works okay and prolongs my cell cleaning cycles...
Aug 10, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Salt level indicator not showing
of corse no:
there a sensor of salt independent of water hardness
so you can change the salt sensor if the problem persist
thank you
Jul 10, 2009 | Dishwashers
Powerpoint dishwasher TW26
cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
May 02, 2008 | Dishwashers
Whirlpool ADP 5966 Dishwasher using the complete salt load in 6 washes and coating all the dishes in salt that would not rinse off. I filled the salt and 6 washes later it was requiring a new load of...
Hello, we are sorry to hear that you are experiencing this problem with the Dishwasher. We would recommend having a certified technician out to diagnose the problem. If you would like further assistance you can send your name, phone number, address, model/serial numbers and the date on which you purchased the Dishwasher to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
