Question about GE Refrigerators
Freezer leaks water out the bottom
Water leaks out of the freezer there is a puddle in front of it daily and something inside is red and makes a sizzling sound like water is dripping on something hot
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Posted on Mar 24, 2014
  • 1462 Answers
SOURCE: Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Posted on Jul 13, 2007
  • 1462 Answers
SOURCE: sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Posted on Sep 25, 2008
gaeb7
  • 25 Answers
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
peyton32034
  • 410 Answers
SOURCE: Water was dripping in bottom back of freezer. Coil
What you observed is the automatic defrost system at work. There is a heater coil (the red hot tube you saw) that comes on at various times to melt frost off of the evaporator coil. This cycle generally lasts 25-35 minutes and then the refrig will start back up and resume its normal cycle.
The water that melted off the coils drips into a drain pan under the unit and will evaporate from the heat and air movement from the compressor. Everything you expereinced is normal and nothing to worry about. thanks Peyton...
Posted on Apr 03, 2009
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Posted on Aug 09, 2009
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
