Question about Behringer XENYX 2442FX Mixer
RESET ON BOARD FX
HOW TO RESET THE ONBOARD FX PROCESSOR..AND WHEN THE CLIP LIGHT IS ON WHAT IS HAPPENIG..
    Sergeant:
  • 336 Answers
The clip light means your input signal is too high and distorting. Turn down the attenuator(input) knob until it goes out, use the channel volume for level. It should have a knob for the names of the effect selection.
Posted on Mar 29, 2014
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
How do I connect a rack mount effects processor to a Peavey 8600D mixer?
  1. On the front panel you want to take a 1/4" cable and plug it into the "main" (output), and then connect it to the input of your fx unit (left is usually mono, if not it will be marked). Then take the output (corresponding to the input) of the fx unit and put it in the power amp in. The 8600D is NOT a stereo unit (this is why there is only one main output).
May 17, 2014 | Peavey XR 8600D Class D Powered Mixer
How to set onboard fx processor
Which clip light on what and what mics are you using?
The small room settings are from 10 so just turn the know to the setting you require and press it, this should set it.
The stadard way of setting up mics is to set the channel gain so the channel clip light just blinks occasionally when you are making the maximum sound you can into the mic.
For effects repeat this process using the aux send FX for each channel you want fx on (turn the rest to 0) and doing a balancing act between these and the aux send fx master so you can only just get the FX clip light blinking occasionally.
Next set your gain/attenuators on the amp(s) so its clip warning can just trigger when you are giving it 0db when you are playing the loudest you ever will.
A mic fading away could be the battery dying (in which case try using phantom power) or if they're radio replace the batteries before each service. If they're wired dynamic mics then it is possible there's some protection circuit somewhere that's reacting to the constant clipping and backing off the amp.
Mar 22, 2014 | Behringer XENYX 2442FX Mixer
2004 Dodge Ram light for H/Air Cond.&Temp.Control Knobs
Very common situation, the main boards are all put together by robots and the small components are available to the manufacturers but not for general resale. Try an electronics store, im sure they would have what you are looking for. It may pay to take the board in. Some boards have the size / spec of the onboard parts written on the board.
Feb 22, 2014 | Bulbamerica Optima Lighting MATRIX Stage...
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Beringer Xenyx 1204fx emits a clicking sound... Sounds like a Geiger Counter for radiation in my headphones. I have used the same sound mixer in the same configurations for 3 weeks. Now I've had it...
This is likely a problem with the FX in the unit or the power to it. Does the FX display act correctly? Check that the headphone source "Main Mix" is the ONLY button down for the headphones. If not, make it so. If the clicking is still there, try the headphones in the aux send jacks... see if EITHER left or right can hear the clicking. Back in the phone jack, scan across the SOLO channel buttons down one at a time. Is there clicking? If not, the problem involves the mixing buss or further down the line. Make sure the SOLO buttons at the FX Aux sends are up.
What effect does the MODE button have in SOLO and in PFL? Is the SOLO LED off? Is the number in the FX window SOLIDLY on and not flashing?
Apr 05, 2011 | Behringer Xenyx 1204fx
How to send effects to microphones
You CAN'T send ANYTHING to microphones since they are INPUT devices.
If you want apply effects to the audio coming FROM them then this is what you do:
Adjust the trim and faders for normal use and verify the mics are working.
NOW for those mics you want to put effects on, turn the knob labled "FX" above EACH mic FADER that you want effects on... it will be the orange topped ones... about the fourth one up ablve the PAN and the two MON knobs. Adjust these to send each mic into the effects mixing buss. Start by setting them at 12 o'clock. You will use these to proportion the amount of effects applied to individual mics.
Next, advance the FX fader/slider to around the Unity mark... this controls the amount of the FX mix buss goes into the FX processor.
Next adjust the knob above the MAIN fader that says FX to Main. This controls the amount of the FX that is sent into the MAIN mix buss...
We are almost there... Select the effect you want with the effect knob to the number of the effect you want... it will be blinking AFTER a change... the effect will NOT have changed yet... WHEN you want the effect to take effect, PRESS DOWN on the effect knob and the effect number will stop blinking and you now have the effects on those mics... ADJUST the three level things... the knbs under each channel to proportion between the mics... adjust the FX fader for the USUAL control of effect amount... and finally the FX to main knb to set the limit of the effect going to the MAINS.
Feb 13, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
The FX portion of the board is clipping with no input signal present, there is no sound output at all. Also, none of the mute/pfl LEDs light up on channels 1-12.
There are several clipping indicators on this board. Do you mean that the small vertical display to the left of the FX selection window is maxed out from top to bottom? I will assume that you have ALL the FX inout knobs CCW for all channels AND the FX slider all the way down. Also does the FX selection knob work to change the effect number? Does the rest of the board work? WILL the effects pass sound when you send it through the effects? You say no sound, but was that just to say with no sound sent to it it still is clipping, or that it will not pass sound?
Oct 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer XENYX 2442FX Mixer Logo
127 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
