Question about Garmin GPS
Garmin GPSMap 450s interfaced to ICOM IC-411 VHF/DSC radio. Settings on the GPS to make it communicate time and position data to the radio for automatic transmission with a distress call, please?
  • david_godfre Jun 16, 2009
    From factory default settings, I have changed serial port 1 setting to NMEA In/NMEA out, all NMEA sentences ON and WAAS/EGNOS (whatever that is!) OFF at configure > system.
  • 749 Answers
Reset the devise to its factory defaults.
Posted on Jun 16, 2009
  • 3,230 Answers
In this situation you need to reset your GPS system,
reset your GPS to factory default setting and than try again.
Good Luck!!
Thanks
Posted on Jun 14, 2009
Can I use an Icom AT-180 ATU with my ICOM IC-7300 HF radio
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Feb 18, 2018 | Icom Radio Communications
How do I connect my Garmin GPSMAP 451 to a Standard Horizon GX1200E VHF radio, eclipse DSC?
Hi
You'll need to identify and connect NMEA out (+ and -) from your 451 to NMEA in (+ and -) to your VHF to get it done.
Hope this is helpful.
-Steve
May 04, 2015 | Garmin Boating
IC-A210
I can to see on Panel Screen ICOM IC-A210 message RX error
Feb 01, 2013 | Icom IC-A210 VHF Airband Transceiver
I have an ICOM IC M505 marine VHF which is the closest model to the one described below. It is less than 3 years old. The channels have been very quiet including channel 16. This prompted me to test the...
Probably not the squelch but the speaker on the VHF. These radios are famous for crapping out when getting wet.
Try listening to the weather radio VHF ch 01, 02, or 03. depending on your location and play with squelch.. Keep in mind they do make external speakers you can hook up.
Jul 24, 2017 | Icom IC M504 Black Submersible PLUS Marine...
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
Connecting Garmin GPS 152 to VHF Radio Silva S15
Hi!
From the S15 owners manual (Page 46):
http://www.bluemoment.com/manuals/silva_s15.pdf
The RED wire is GPS data,
The green wire is GPS ground.
Hope this helps and good luck!
May 08, 2010 | GPS
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Jun 16, 2009 | Garmin GPS
GPS Logo
61 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
