Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Need to remove rear wheels to replace tires on MTD riding mower.
Inherited a 10 year old MTD riding mower with no schematics. Runs fine, but I need to remove rear wheels to replace tires. Only a screw with washer seems to be holding wheel to axle. Removed this, but cannot get wheels to come off axle. Tapped inside around axle, but wheel comes only 1/2 inch or so. Is there something I missed, or another way to do this?
  • 1 more comment
  • johned44 Jun 15, 2009
    2x4 worked great as a battering ram. Sprayed the axles several times with liquid wrench that I had, letting it soak for a few hours, then knocked both wheels off in about 20 minutes as suggested. Thank you very much! Now all I need is to find new tires and get them mounted.
  • Anonymous Mar 22, 2014
    This happened after I removed/replaced the deck and rear wheels. The transmission bypass lever is pushed in. Rear wheel axle pins are in place and the drive belt is attached but it is very loose. The drive belt is not moving. What am I missing?
  • Anonymous Mar 29, 2014
    remove rear tire
  • 284 Answers
Most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
How to remove the rear wheels from a mtd lawnflite ride on mower
they just need bumped off after the bolt is removed .they will be rusty so some penetrating oil will help a lot
Feb 17, 2015 | Mtd Garden
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
How do you remove the rear wheels on a ranch king plus 18 hp 46 inch cut
if the don't come off after removing either the bolt or clip and you need to change a bad tire just change the tire on the axle jack up the one side as high as you can not as hard as getting the wheel off
May 04, 2012 | Mtd Garden
Remove rear wheel
What is stuck? The bolts? The wheel is stuck after removing the bolts?
Apr 22, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I currently have an MTD Yard Machine - 12.5 HP with a 38 inch cut - it is over 10 years old. I wanted to change the tire and was able to remove the bolt, but cannot get the wheel/rim off the axle. I'm not...
Your wheel must be rusted to the axle. Try WD40 or you might have to apply heat with a blowlamp. You would need to be very careful doing this. You could change the tyre without taking of the rim. Stephen.
May 06, 2010 | Garden
Do you need a puller to remove tire off a yardman riding mower?
If you have successfully removed the wheel, You should be able to remove the tire, from the wheel, simply with a flat headed bar, or two.
Deflate the tire, then apply pressure, to break the bead.
Then insert the first bar to lever the tire over the edge.
Carefully repeat the process, and there you go.
Happy mowering:)
Jul 24, 2009 | Mtd Garden
Axle came out of rear end
solution was to fing the 10 year old owners manual and look at the exploded diagram..and yes there was a clip holding the axle in...next was the fun task of dropping the rear end and opening it all up.
Oh Boy!
Apr 28, 2009 | Craftsman Garden
Remove rear wheet
YOU'LL NEED AN EXTENTION FOR A SOCKET,BUT 1'ST REMOVE THE LITTLE CAP AND REMOVE THE COTTERPIN,MAKE SURE IT'S IN GEAR IT WILL KEEP THE WHEEL FROM TURNING.hope this helps
Apr 25, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
REAR WHEEL REMOVEAL
it depends on which style mower most ayp (poulan craftsman husquvarna....) are put on with a e clip they may become froze to it but can be removed. now most mtd (yard man yard machines bolens troy bilt...) have a revers thread bolt with a tapered shaft trust me i worked on theses for 10 years. why would you want to take it off anyway? everything can be done with it still on
Dec 08, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
4,359 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
