Question about Hitachi 50GX30B 50". Rear Projection Television
Color Allignment The blue in the television is completely misaligned.  When I go into the digital array I am able to fix the red, but am unable to move the blue at all.  I think that my blue bulb is broken, but it still projects onto the TV and works fine other than the fact that it doesn't want to be aligned.  Is there any way to correct the colors by hand?
  • bjredstonetv Aug 27, 2008
    blue line going across the screen 2 and 3 will not move when you are doing the array.
Have to change the convergence blocks and check rezistors
Posted on Apr 18, 2008
Press menu on the remote and then u will be able to align the blue
Posted on Nov 18, 2007
Auto convergence yields with unable to complete due to unresponsive sensor
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Mar 05, 2012 | RCA HD56W58 56" HDTV
Colors seem to be out of sync
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 14, 2010 | Philips 55PP9401 55" Rear Projection...
Projection TV red is drooping
Do an internet search on "Hitachi Convergence Circuit". This apparently happens all the time. TV repairmen charge about $400. Parts are less than $50 but you would have to be an expert at soldering electronics circuits to replace it yourself.
My TV had the Blue misalign instead of the Red. I ordered the kit #9 from http://www.bdent.com/search/part.jsp?partnum=KIT9
DO NOT ATTEMPT IF YOU DO NOT KNOW HOW TO SOLDER. YOU WILL PROBABLY RUIN YOUR TV.
Aug 15, 2008 | Hitachi 50GX30B 50". Rear Projection...
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Red color allignment
The convergence Ics need replaced. In Toshiba, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Mar 31, 2007 | Toshiba 50H72 50" Rear Projection...
Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Nov 13, 2006 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50GX30B 50". Rear Projection Television Logo
267 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
