Question about Oliso Irons
Steam button wont come back up
Steam button is stuck
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
Tip
How to release the stuck steam button in Shark iron-61468-10?
If the steam button is got stuck in the down position in your iron then follow this procedures to release the stuck button:--
1) First of all pull the button up. You may have to coax it up; you can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only).
2) Below the button is a stem that operates the valve, gently pull it back up with a pair of needle nose pliers (careful - the stem is made up of plastic material).
3) Then replace the button (align the stem into the hole on the bottom of the button to its exact position. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :)
It seems like it sticks when the iron is left unused condition for a period of time; as if the valve gets stuck up when dry. leave water in it this time, although the instruction manual says not to. But leaving the water in it may not let it get dry.
This will help.good luck.
on Feb 28, 2010 | Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Steam button stuck
put some vinegar in your iron and swash it around. It will remove the calcium or lime that is making your button stuck. Be sure to run a lot of water through the iron after or your clothes will stink.
Apr 24, 2013 | Black & Decker Irons
Phillips double-speed 2.5 bar reservoir heats but will not steam
Thermistor is probably damaged, and the machine does not identify that the steam is ready (max temperature was reached) and pressing the steam button wont do anything. Change the thermistor (should be carried out by professional technician).
Jan 04, 2013 | Philips Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
The rocker button to enable steam to flow seems stuck. It will not rock.
The stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free.---------------- Pull the button up. You may have to coax it up; You can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir.It seems like it sticks when the iron is left unused for a period of time; or the dirt get collected under the button.As if the valve sticks when dry. You can leave some water in it when not in use. --------- This will help.Thanks.Helpmech.
Jul 11, 2011 | Rowenta DG-980 Iron
DG-980 Iron: The button to use the steam is stuck. I was ironin...
Hi Mary, sounds like something jammed in the trigger mechanism or the microswitch button is stuck in the housing. Unplug the iron, let it cool. Gently pry up the blue cushion from the handle from the front towards the rear cord, you will see the trigger, the actuator tab and the microswitch button (nib) that should be sticking out, if it is flush with the housing it is jammed down. That switch is replaceable, but I don't know how savy you or your appliance servicer are at replacing it. Here is where I get my parts:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Please keep us informed as to your progress resolving this...
May 18, 2010 | Rowenta DG-980 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Irons Logo
64 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
