Question about Techko SH1524CP Shredder
Paper jam light is on
How to take unit apart
How do I fix a printer error
turn the printer off..then after a while it turn back on, the jammed paper will come out automatically if it doesn't pull the paper towards you not the other way pull it forward until it is totally outside the exit tray.. dont pull it on the feeding unit cause it will damage the feeder unit and the paper might tear apart leaving a piece of it inside that would be more difficult cause you have to open the entire printer unit.
Oct 02, 2014 | Canon PIXMA Office Equipment & Supplies
Paper jam light will not go off and there is not paper jam in the unit.
Over time paper dust and toner residue can build up around the drum and paper feeder rollers. Open your printer and remove the toner cartridge and Drum unit. Use a soft brush to clean any residue. Replace toner cartridge and drum unit.
A tiny bit of paper can cause the paper jam light to stay lit.
Jan 16, 2010 | Office Equipment & Supplies
Paper feed clicks does not feed paper from tray.
there is most likely something jammed in the gears. take it apart and check all the gears.
Jul 31, 2009 | Canon LaserBase MF5750 All-In-One Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Nov 10, 2008 | Dell 1710n Laser Printer
Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Jun 13, 2008 | Fellowes PS70-2CD Shredder
Jamming
When these printer had a jam whatever is stuck in it is usually found deep down in the paper feeder where u can't visibly see it, to be certain nothing is stuck in there you'll need to take it apart, its not difficult as it contain just a few major components but be careful how you take it apart. You'll to take off the two side covers the scanner unit and the top cover then just a take flat screw and slightly raise the white plastic paper guide and see if its anything there.
Mar 25, 2008 | Canon PIXMA MP160 All-In-One Printer
Huge paper jam ( piece of a checkbook)
Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
I would buy a cross cut shredder next time.
Hope that helps.
Jan 19, 2008 | Techko SH1524CP Shredder
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Techko SH1524CP Shredder Logo
44 people viewed this question
Top Techko Office Equipment & Supplies Experts
Randy Schumann
Randy Schumann
Anita Nystad
casper muchato
Level 1 Expert
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
