Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Need part number for oven element
Oven element is not working and need part # to order another
  • Linda Power
    Linda Power Mar 22, 2014
    Model # is CVDSC3674GSS - the model # above was posted in error
    Champion:
  • 203 Answers
Try a company called e spares on the internet give them the part no and they may have one
Posted on Apr 03, 2014
4 Suggested Answers
  • 42 Answers
SOURCE: Viking Wall oven Electric - Botton element doesn't work
there isn't a fuse. if you could confirm you have 240 volts going to the element that would tell you replacing the element should fix your issue
Posted on Dec 21, 2008
appldoctom
  • 311 Answers
SOURCE: Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Posted on Jan 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: bad lower oven element
Directions
Posted on Jul 03, 2010
Whirlpool oven dony heat up to the temperture
You likely have an oven element that is burned out. The elements can be replaced. Determine which element is burned out and put your hand near the element with the door open to see if if is the bottom or top element that is burned out. Then go on the web to an appliance part sales company such as appliance parts.com. Enter your Whirlpool model number and do a search for heating elements.
Order one. When it comes, turn off the power to your oven. (go to your house power panel and turn off the breakers that feed the oven.) Back to the oven. Open the oven door and look at where the element comes out of the oven wall. Undo the two screws, pull the element out through the two holes in the oven wall an inch or two. If you find insulation coming out with the wires, push the insulation back into the hole so you can just see the attaching electrical wires. Find attached to the old heating element a electrical wire connector with wire going back on of sight into the hole in the oven cabinet, one for each element end. Unplug the connector. You may need pliers to wiggle it while pulling off. Reverse the installation. Plug the connectors on to the ends of the new element. Reinstall the two screws that hold the element to the wall. Turn the power back on to your oven. Give it a try. It should work and is the most common reason why your oven would not get up to temperature. Likely one of your two elements is burned out.
Nov 04, 2014 | Whirlpool WFE510S0AS 30" Freestanding...
What oven heating element?
Hello Mary, I am happy to assist you!
I understand that you are unable to read the model number in the storage drawer of your Frigidaire range and that you are seeking the replacement part number for the element in your oven. Are you needing the bake or broil element? Do you remember if you register your range? In this regard, I would highly recommend reaching out to the manufacturer directly to verify if indeed your range was register in order to provide you the correct part number. Best regards - Z
May 05, 2014 | Frigidaire Kitchen Ranges
Can't find model number for old Hotpoint custom oven
Hi Marcia,
It's going to be difficult to locate parts based on a catalog number - as you have learned, parts are based on model numbers.
You may want to do a little bit of testing before you embark on finding a replacement element. I would remove the element from the plug in socket and measure resistance of the element itself (20 to 40 ohms is typical), or voltage at the socket with the oven set to turn on the bottom element. Assuming a 240 volt oven, you should see this same voltage present at the socket. If you do have the voltage, locate a replacement element. If you do NOT have this voltage, you need to locate the source of the failure and have it repaired or replaced. You should inspect the metal plate on the element to see if a part number is present on it - as that will solve your parts identification issue.
There's not a huge difference in a lot of these elements besides physical dimensions of the element and between the connections for the socket. Have a look at these Hotpoint parts & GE parts and see if any of them looks like yours and then go from there. Some of the appliance repair parts sites might even be able to help you with the catalog number issue, too.
I hope this helps & good luck!
Oct 17, 2012 | Ovens
The baking element isn't working.
You can replace the element. The element should just plug in to the oven. You might have to remove a few bolts that hold the element in place. Get the model number of your range and call your local appliance stores, or order it online. Unplug the old element and plug in the new element.
Apr 28, 2010 | Kenmore 96012 / 96014 / 96019 Electric...
Oven powers up but doesn't heat
When you turn the control to 350 or so the bottom heating element should heat up, if it don't, turn the control to broil if the top element heats up it is most likely the bottom element has burnt out and need replacing. You can find the elements at Home Depot or Lowes, if not in stock at the store, you can order it inside the store.
Feb 13, 2010 | Ovens
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Jan 07, 2008 | Ovens
Belling XOU252 (Broken Oven Element?)
Open oven door, remove shelves and unscrew light cover. Remoe the 4 screws from the backplate, one in each corner and the element is behind the cover. Any electrcal shop should be able to get one for you
Jul 09, 2007 | Belling XOU252 Electric Single Oven
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
69 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
