Question about Marantz PM7200 2-Channel Amplifier
Distorted sound / fuse blows off when changing amp class.
Hi, After quite a long time I started my amp and immediately noticed that the sound is badly distorted in the speakers. Tried to fiddle with the controls a bit and when I switched off the Class A button the fuse blew off (the one in the back-left side of the amp). Changed it, but it blew off again when I started the amp. When switched back to class A its working but distorted as described earlier. Regards, Kris
    Top Expert:
  • Marantz Master
  • 22,777 Answers
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Posted on Mar 22, 2014
3 Suggested Answers
Grubhead
  • 5158 Answers
SOURCE: Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Posted on May 04, 2009
petraman7
  • 1175 Answers
SOURCE: Hi, i have a marantz
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Posted on Aug 20, 2010
Testimonial: "Hi Petraman7, Cheers for your reply i think your right, i'll have to have a tech guy to look at it, any idea how much it could cost. Cheers Paul C"
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
It sounds distorted when the music gets louder
Time to start upgrading! Think power delivery, then amps, then speakers, then enclosures.
If you need more voltage, add batteries, capactors etc, if you're exceedingg the amp output range, you'll blow speakers (no matter what the speakers are rated for), if you have good power and the amp(s) are fine, your speakers may not be up to the task
Feb 08, 2014 | Kicker Car Audio & Video
How to change 80 amp fuse on 2008 Chevy Equinox
Locate the fusebox
Locate the 80amp fuse you wish to replace
Remove the old fuse
Take new fuse and insert it into slot
Test the fuse by seeing if the electronic that runs on itsit is working
Oct 13, 2013 | 2008 Chevrolet Equinox
Fuse 42 radio system blows immediately after
Does fuse blow as you switch radio on/or radio still off
Either way ,remove radio,check connections for damp ingress
To remove radio go to fitaudio.com
Jun 19, 2010 | 2001 Volkswagen Beetle
30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Apr 12, 2009 | 1996 Hyundai Accent
My bass guitar amp is blowing fuses
This sounds like the main rectifier diode/bridge is shorted. If you can rpovide the make and model, I may be able to give you more details.
Thanks,
Dan
Nov 25, 2008 | Audio Players & Recorders
Amp won't put out sound
A lot of Amps come with fuses as a safety mechanism so you don't blow the speaker and/or internal components in the case of a power surge etc. Check for a blown fuse. Sometimes they have a fuse holder in the back of the amp and it is labelled "fuse" which cetainly makes it easier to find. Hope this works and helps.
Nov 17, 2007 | Prime 40 Watt 2 Channel Lead Electric...
Pioneer sd-643hd5
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Marantz PM7200 2-Channel Amplifier Logo
105 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
