Question about LEC TF50152W White 172 l Fridge Freezer Bottom Freezer, A Energy Rating
Lec fridge-freezer TF5089 faulty door light switch - how do I remove the switch from the fridge to check it?
Fridge light remains on even when door is closed. Tried to remove door switch to check it, but it is very difficult to prise out. I get it partially out but afraid to force it more for fear of damaging it. Advice needed on how to remove it without breaking it - thanks.
  • 245 Answers
Prying it out is the only way I know of. When you get it partially out you may be able to get hold of it with waterpump pliers or regular slip-joint pliers adjusted for a wide grip, and pull it the rest of the way out. They are made to be removed this way, so it shouldn't be damaged. If you push in the button and the light remains lit your refrigerator section may not be getting cold, because a bad door switch can send out a signal that the refrigerator door is open, in which case the freezer may not be blowing cold air into the refrigerator section. The door switches are fairly cheap online, especially compared to a service charge.
Posted on Mar 23, 2014
Testimonial: "Thanks for that, see comments below for more details."
  • Joseph
    Joseph Mar 24, 2014
    Thanks for that. While waiting for help I browsed the internet and found a photo of the door switch that showed its spade terminals to be on the top surface, so I had another go at removing it by inserting a thin steak-knife blade under the base of the switch and, with considerable force was able to get the switch out. I now know that it has a 'sprung' plastic catch over its lower surface that should be released by inserting a thin screwdriver blade to compress it and allow the switch to be withdrawn. Testing the switch proved it was not faulty though, and the fridge light stayed on with the switch disconnected! :(. I've now removed the bulb and the fridge stays cool, but I've yet to resolve the fault - the main one being that the fridge-freezer shuts down after one cycle and needs the defrost timer (which is not faulty) to be manually "clicked" to restart it. Very frustrating!
How to fix lec l5026w fridge on top of freezer?
There should be brackets that would attach to the back of both to hold them together and in place, similar to a stackable washer and dryer
Sep 07, 2012 | LEC Refrigerators
Replacing door interior light switch of under counter LEC fridge
If it's the rectangulat one, it prises out of the hole with a flat screwdriver. Make sure it's unplugged before working on it. Do you suspect a faulty switch?
Apr 24, 2012 | LEC Refrigerators
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
LEC TF50152W White 172 l Fridge Freezer Bottom Freezer, A Energy Rating Logo
117 people viewed this question
Top LEC Refrigerators Experts
mike cooper
Vernon Taylor
Are you a LEC Refrigerator Expert? Answer questions, earn points and help others
