Question about Water Filters & Coolers
Cold water stopped dispensing
Model YLR2-5V116c Classic hot and cold water cooler Cold water tap just started slowing down and then stopped working working, hot water button is fine and dispensing properly. Please advise soonest, thank you.
  • 14 Answers
SOURCE: No Cold Water
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing.
Posted on Jul 10, 2008
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
SOURCE: sunbeam cold and hot water dispenser
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
SOURCE: cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
Posted on Jul 24, 2009
SOURCE: Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
LEAKS
Posted on Sep 02, 2010
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Dec 26, 2010 | Microwave Ovens
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
Dec 18, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Water not getting cold
see if the compressor is working or move the thermostat to a highter level
Dec 29, 2007 | Whynter FX-6SW Free Standing Hot & Cold...
Water Filters & Coolers Logo
79 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
