Question about Watches
Ohsen led-1003 battery replacement
I can get the back off of the watch but then am stumped. There is some sort of cover but it seems flimsy and I dont want to bend/break anything. Has anyone does this successfully?
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
SOURCE: Cannot re-attach back cover - WR30M
Yeah, I had this problem on a Timex Indiglo, but didn't have it on the cheap $20 watches in drug stores and discount stores. Timex puts a tighter cap on the back, probably for quality reasons, and you cannot push it together by your thumb. --This solution should work for about anyone: 1. Put the watch face down on a hard surface, but protect the crystal from scratching by putting a piece of cardboard or cloth between them. 2. Align the back and put a socket from a socket set on it that is somewhat smaller than the back cap. 3. Tap the socket with a hammer. You don't need to tap hard--even less than what would start a small nail. It may take only one tap--getting it aligned right is the key.
Posted on Oct 11, 2008
escapement
  • 2334 Answers
SOURCE: Cannot get the cover back on Fossil watch after changing battery
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Posted on Dec 21, 2008
escapement
  • 2334 Answers
SOURCE: I need a replacement battery for an original navy
If anyone opted out to replace battery2_bing.gif in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries2_bing.gif, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
Rate me, plz.
Posted on Jan 29, 2010
  • 3 Answers
SOURCE: Ohsen red L E D watch
Hi Mate, Did you solve this problem?
Posted on Jul 28, 2010
I have a Ohsen AD0926 and need to replace batteries, what batteries does it take?
only a person that opens it up can tell you that, Personally I use the jewelry counter at local walmart .
Sep 17, 2015 | Watches
Where can i get a battery
Easiest way is to take watch to a watch repair, jewely store, or big box store like Walmart. They can sell you that battery and install it for you.
To determine the battery type, you will need to refer to your manual, or you can try looking on the back of your watch (which sometimes lists the battery type.)
Apr 01, 2015 | Ohsen YI-0815-4 LCD Silicone Digital...
Where can I get a battery for a Ohsen wr30m Watch?
Easiest way is to take watch to a watch repair, jewelry store, or big box store like Walmart. They can sell you that battery and install it for you.
Apr 01, 2015 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Ohsen AD0721 will not light up
bad led light or low battery.it takes away functions
Jan 31, 2012 | Watches
I have a small acqua watch and after replacing the CR1612 battery i can't seam to get the cover back on. there is no notch on the back cover so orientation may be a problem. the only markings on the back...
I suggest that arrow points to where the case back should be opened. Check if there are any writings on case back. When the watch's opened back is facing you (winder to the left), these letters should be normally readable (not upside down) with case back attached to watch. If there are no writings, check inside case back - there should be small groove on one side. This side should be aligned with the stem (the piece going from winder into watch).. Hard to say without seeing it, but hope it helps. Be aware: to fit the case back back on watch may require significant force.
Feb 27, 2011 | Relic (0504529FA)
Instruction manual for Ohsen AD0721 watch
I tried contacting both the eBay seller and the watch maker and what I got was a complete joke. So I figured it out on my own (mostly) and made a real manual for the watch (attached to this posting).
Oct 21, 2010 | Watches
Watch is too flimsy to change battery!!!
You can only go back to the supplier and explain the situation. At the price of these watches you should expect to get some product support long after the warranty runs out.
(can't help wondering why such a short warranty is offered on a mechanism that you can reasonably expect to work for many years.)
Jan 16, 2010 | Vicence Rectangular Watch
Nov 22, 2009 | Bulova Watch
I need instructions manual for ohsen AD-0806-2 model
Hi,i need instructions manual for ohsen AD-0806-2 model
Nov 13, 2009 | Bulova Watch
Watches Logo
54 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
