Question about BMW 2002 325XI Radio / CD Player g63113241i on-board monitor computer trunk San Francisco, California
Removed battery from bmw 325xi now radio wont work warning lights are on
Radio wont work warning lights are on
HGComputers
  • 81 Answers
SOURCE: Need fuse panel diagram for 2002 BMW 325xi
This is what I could find. It doesn't have a steering whee radiol control fuse but has 2 fuses for the radio. It seems to be the same panel across the board for BMW's. 4x4's, diesels, gas, 6 and 8 cylinders, etc. Hope it helps.
Posted on Jan 12, 2009
  • 145 Answers
SOURCE: changing headlamps on 2003 bmw 325xi
I am assuming that you have a burned out head light bulb.
1) Open hood.
2) Working in back of headlight assembly, grasp rear of bulb socket (harness connector) and turn counterclockwise 90 degrees. Pull bulb out of headlight assembly.
3) Disconnect harness connector from bulb (gently pry, it's plastic)
4) Installation is reverse of removal. (Do not touch halogen bulb with bare skin-oils from hand will cause bulb to burn out.) Align tabs on bulb base to cutouts on rear of lens assembly. (Note bottom tab is wider than other two) Secure bulb by rotating clockwise 90 degrees.
Low beam bulb H9006
High beam bulb H9005
Posted on Jan 23, 2009
SOURCE: 2003 BMW 325xi won't start, dashboard and radio go on.
My 2003 325xi died on the highway a few weeks ago, and I thought it was the battery. It turned out to be the alternator, which was an expensive problem to repair. If your battery is new, it could be the alternator, or a problem with the electrical system. I find the BMWs to be too complicated electrically, which often leads to problems! I'd check your alternator...
Posted on Aug 08, 2009
SOURCE: my 2002 bmw 325xi fuel filter location?
It is on the drivers side on the chassis.
yes you can change it yourself. Make sure you de-pressurize the system before removing (undo the gas cap).
Also...order the filter from bavarian auto or one of the online stores. The one you need is with the pressure regulator.
If you go to autozone, etc. they will sell you the worng filter.
Posted on Jun 11, 2010
SOURCE: BMW warning lights: BRAKE, ABS and DSC
i need anyone one to help me with this problem, i have a BMW328ci and i tried tyo get out of my house this morning and all roads were frozen and the car started sliping and i activated the dcs button and car was still slipering and then brake, ABS, CBC & DSC lights turned on and i need to know how i can reset these lights so they can come off
Posted on Jan 12, 2011
Bmw 325 xi navigational system will not turn on
If the fuse is blown it could certainly have something to do with it.
Nov 15, 2013 | 325xi Socket mount. Cigarette lighter /...
2002 BMW 325xi Air conditioner
your unit may need recharged your vac lines may be bad going to crntrol head the static could be a bad ground at blower
Jun 30, 2012 | 2011 BMW 325xi
Car wont start, but all lights work....Theres no turn over sounds at all, car simply wont even budge, but all signs of a bad battery are no there, all electrical things work.
SOUND LIKE FAULTY STARTER SOLENOID OR STARTER MAKE SURE BATTERY CABLES AND BATTERY POST TIGHT CLEAN TURN OFF RADIO FIRST BEFORE REMOVING BATTERY CABLES. TO KEEP FROM LOSING CODE. USE A MEMORY SAVER IN CIGARETTE LIGHTER BEFORE REMOVING BATTERY CABLE.BMW WARNING YOU BECAUSE YOU SHUT DOWN PCM VECHICLE HAS TO BE TOWED IN AND REPROGRAMED .IF ALL IS GOOD YOU COULD HAVE PROBLEM IN ELECTRONIC IMMOBILIZER CONTROL OR FAULT IN THE TRANSMISSION CONTROL UNIT.
Jan 31, 2011 | 1999 BMW 323 Series
I have a 2002 bmw 325xi. i go to start it and all the lights and radio come on but it doesnt start. I just hear a clicking sound? 1st time it happened dont know what the problem is.
The clicking sound you hear is the solonoid on the starter trying to engage your starter into the ring gear,in my opinion i would say that the starter is jammed (needs replaced) but be sure to get the battery checked first as a low battery voltage will result in a poor crank effort aswell,Hope this helps!
Feb 17, 2010 | 2001 BMW 325
03 325xi radio stopped working
good day, it maybe a bad electrical problem. you may try to check on the fuses and replace it if busted. hope this helps, have a nice day
Feb 10, 2010 | 2003 BMW 325
BMW 325xi; 160k; check engine light on-->next day, wont start!
I would try to jump it to see if the starter engages and the engine runs, if it does you have a connection problem between the engine starter and the battery, if it does the same thing with cables then you will probably have to tow it in to the shop. I do not think your problem is related to cold weather, but it could very well be related to the check engine light. Exactly what the check engine light is on for I can not say with out a code, but I agree with your thinking about taking it to the shop. Hope this helps, let me know.
Dec 11, 2009 | 2003 BMW 325
Nov 18, 2009 | 2003 BMW 325
Aug 08, 2009 | 2003 BMW 325
Changing headlamps on 2003 bmw 325xi
1) Open hood.
Low beam bulb H9006
Jan 07, 2009 | 2003 BMW 325
BMW 2002 325XI Radio / CD Player g63113241i on-board monitor computer trunk San Francisco, California Logo
65 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
