Question about Acer Aspire One PC Notebook
Screen flickers My screen on my Acer netbook constantly flickers. It is so bad, can not read the screenHow do I fix this?
    New Friend:
SEAM TO HAVE SAME PROBLEM TRY RUNNING IT WITHOUT THE BATTERY INSTALLED
Posted on Feb 06, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Probaly a defective inverter or ccfl tube
Posted on Jun 14, 2009
Very dim LED screen on Acer One D255E netbook
The laptop video circuits are good and the fault lies with the display or the power feeding the display.
Go for the display since they do go bad.
Aug 25, 2017 | Computers & Internet
Screen flickering after hibernate/sleep
in your keyboard system problem just unplug you key broad or outside keyboard use inside you dissable from device manager then check again
May 16, 2012 | Acer Aspire One D270 AOD270-1492 10.1-inch...
Screen making quick flashes
This could be a LCD screen problem or a video card problem.
Connect an external monitor to your laptop, power up the monitor first then boot up your laptop. The video will automatically switch to the external monitor, then go to the Internet and see if this flicker occurs on the external monitor.
If it still flickers then the video card has a problem.
If it does not flicker the the LCD screen maybe faulty.
Get back to me with the results of these test and I can advise the nexr course of action.
Apr 30, 2012 | Acer Aspire One Netbook
It was dropped and the screen is messed up can it be fixed
If the LCD is cracked (likely in a drop, you'll get a rainbow/spider web appearance to the screen)- it is possible to replace it. However you would likely have to purchase the part from Acer directly. I have a sinking suspicion that the replacement part would likely cost almost as much as a new netbook- I would check. So yes, it is possible to be fixed, however it may not be worth replacing the part.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen is flicking again and agin Model is ACER Travelmate 5730
If the screen flickers when the lid is moved, then it is most likely the LCD ribbon cable has a bad connection to the LCD controller board. If it flickers without lid movement, then it is probably the inverter module for the LCD, but if it flickers constantly and especially if there are white lines that stay constant accross the display, then it may be an overheating or failing GPU. Check the air vents on the unit and make sure that there is no blockage if the latter is the case.
Hope this Helps.
Gill
Sep 24, 2010 | Acer Computers & Internet
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
Acer one netbook screen blank on power up due to graphic driver
Does your laptop get past the startup screen? If not, then I doubt it's the graphics card driver that needs to be installed...I worked on an Acer One netbook a while ago and I found out that the wireless card was the problem. I took it out and the laptop worked fine ever since. I think I've read somewhere that Acer One's have a problem with their wireless cards. Though, it is a pain taking out the wireless card since you have to completely disassemble your laptop.
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
344 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
