Confirmation bias what is meant by confirmation bias?
  • 2,013 Answers
Pilot turns on and so will unit for about. 5 minutes...pilot flickers as if there were air blowing into it...any suggestions? It is. A Pro-com MD100TBA
the flame confirmation thermocouple might need looking at biased on your description , this item sits inside a stainless steel metal tube that's about 1.5 inches long an is someplace around the edge of the heater , this item confirms that the main flame has lit and shuts off the pilot most times too . this is why I believe it is not working
Jan 18, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
Tip
Shorted Rectifier Diode (fuse keeps blowing)
This CRT tv is dead set, no reaction when the power button is pressed(no standby led light). I've open the back panel and check the faulty parts.
As you can see the fuse was badly burnt-out indication of excessive current due to short circuit.
I've checked the parts feeding the AC line to the power supply board (Power cord, VDR, Ceramic capacitor, Coil, Posistor, Degaussing coil) one by one and I've found out that one of the four rectifier diode has a leak which caused the glass fuse burnt-out.
Here's how to test the rectifier diode.
Good Diode
Note : Forward and reverse bias depend on what type of ohmmeter are you using, here I'm using a Japan Standard(Sanwa Brand).
Using an ohmmeter set it to X10 to see much easier the leak from the diode in reverse bias.
Forward Bias : test the diode by connecting the red test prod of the tester to anode and then the black test prod to cathode of diode. You will see the pointer will reads a faily low resistance(above picture).
Reverse Bias : test the diode by connecting the red test prod of the tester to cathode and then the black test prod to anode of diode. You will see at the picture(above) that the pointer didn't react (remains in infinity). This is a good diode.
Bad(leaky) Diode
Forward Bias will reads fairly low resistance.
Reverse bias unlike the good diode the pointer will also reads a fairly low resistance.
After confirming that the diode caused the fuse from blowing I've decided to replaced all four diodes since I have a lots in my stocks.
Remember that when you installing the new diode on the board, make sure that you will make it in the right polarity.
This steps is also applicable in the DVD Player,Flat panel, Projection, LCD TV, you have to disregard only the posistor and degaussing coil.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
on Mar 02, 2011 | Televison & Video
Why wont my lexmark 3300 printer not turn on?
Have you confirmed that the power source is pumping out the correct voltage/amps with a voltmeter, too? I'm assuming you meant that you verified the power outlet works?
Jan 02, 2015 | Lexmark International Lexmark 3300 Series
Aiwa nsx nwvt99 donot power up always in stand by mode
This can be due to an error in the output which can protect the circuit and also it can be due to problems within the power section to the bias circuits. In all these cases if the processor trips off after a switch on then the fault needs a probe using a schematic so as to confirm the loss of voltage.
Remove speakers to test and also check in all source modes to confirm if the fault is related to just one source.
Dec 23, 2011 | Audio Players & Recorders
Sound clarity not good beause distrubing sound
It depends on how the sound is heard, if the sound is distorted then the amplifier section must be checked, It can be fault in the power output IC, fault of the bias or fault in the pre- amp section.
Secondly if the sound is jarring then the speakers needs to be checked, it can be problems on the diaphragms or coils.
You will also need to check or switch source of sound to confirm if this was from a source.
Also an AF signal test and injection will confirm the stage that is effected.
Jul 12, 2011 | Philips HTS 3154 Theater System
Bios password removed
hi to remove the password off the bias, u need to take the bias battery out of the motherboard or change the bias jumpers depending on the motherboard inside of the laptop.
Most motherboard manuals will show you how to do this. The bias battary normally works for all motherboards. You bias setting will reset so it should work.
May 07, 2011 | Toshiba Computers & Internet
PHILIPS VCR WILL NOT RECORD PICTURE, BUT SOUND QUALITY EXCELLENT
Provided that you have given a good confirmed signal into the VCR or is using the tuner to record. If so then the fault is within the VCR recording biasing of the signal. The rrecorrded signals ahve to eb written to the tapes after mixing up the spectrum of information that comes along. failure of theprocessing IC must be the fault to this and will require expert testing within the VCR for signal trace before we can pinpoint. I hope you will need expert help to confirm onthe head amp section/ video processing stages preferably with the manual in hand. Helpful to decide? Good day
Jul 14, 2010 | Philips Televison & Video
Competition winner
That is scam 100% confirmed.
May 04, 2010 | Yahoo Mail
Tascam MF-P01 recorder - hearing nothing during play back
Mine also would not play back on any of the channels but would record. The problem was on the lower board, capacitors C105, C205, C305 and C405, all are 220uF, rated at 10V - on a 9V machine! All four went leaky, which meant that the op-amps each were connected to got a bias which drove the output to 8.5V and no output.
I replaced all four capacitors with new ones rated at 25V and it works again!
Dec 09, 2009 | Tascam Starter Pack for 4-Track Cassette...
Out of balance during wash
Ok you need to check your machine is level- if not adjust feet. You aslo need to check the Bias spring is still attached if not get a new one or re-attach it. The Bias spring is a little spring that connects from the top of the front left suspention rod to the top of the plastic bowl cover (this spring is meant to help stop it going out of balance so easy. Cheers
Mar 24, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
