Question about Gigabyte GA-8I915P Duo Pro Motherboard
Stuck at the begin
When i start a computer motherboard mic start make some signals. tik.....tik.....tik.....tik disconnect everething stay with power supplay, prossesor and 1gb memory. connect disconnect everything. what is it? need help
  • 790 Answers
Try removing the CMOS battery and wait 2 minutes, then replace.
Check the voltage before re-installing it.
Also, check and reseat the memory and processor.
While you have the board out, you should check all the USB ports for pin shortage.
Hope this helps.
Posted on Mar 22, 2014
My truck turns off when i put on the A.C on or the defoger also the radio turns on and off and when I turn on the truck it has a tik tik tik sound.
Very common problem after the battery has been disconnected or a battery change. Clean your throttle body with throttle body cleaner. First disconnect the battery, clean the TB with TB cleaner, must be nice and shiny. When finished, hook the battery back up and drive around for 20 minutes or so with all accessories off, so the computer will relearn a properly functioning throttle body.
Your computer learned some bad habits, so when you changed the battery, the computer thought the throttle body was clean and functioning properly. So when you changed it, this caused all your problems. Very common, keep your throttle body clean, should be done at least once a year. Total cost if you do it yourself is around $5, for the can of TB cleaner.
Apr 13, 2011 | 2002 Chevrolet TrailBlazer
Basically i bought the nt1a second hand and plug it into my preamp and have no problems until i start recording and slowly the pickup of the mic fades away and i have to either make a loud noise to...
Seems you might have a gate inserted on that mics channel. Or if you are going to a computer, the program you are using might have an insert activated with a gate. Which means when signal gets to a certain threshold, the gate opens and the mic signal passes thru, below the threshold...the gate stays closed and the mic signal will not pass thru. Hope this is helpful.
Apr 12, 2010 | Rode NT1A Professional Microphone
When put on the pc, tik tik sound coming from hard disk
Hello my friend.
This is indicates that you have hardware problem on your disk or is very dirty.
The only think you can try before buy new one is to scan it for errors and and do a defrag.
You go to MY COMPUTER
You select your hardrive LOCAL DISK C: etc
Right click-Properties-Tools Check now(Check for errors) Probaply will ask for a restart to scan it,so do a restart do start scanning your disk
For a defrag you do the same but in Tools you choose Defragment now(defrag now)
Jan 15, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Intel D865GBF, having sound-max, is not giving signal to speakers. While using sound-max wizard mic input signals are shown, but there comes no sound in speakers while testing it...
Goto the your Start button, control settings, sound, click advanced, make sure your mic is not muted, and the proper input is selected(usb, or however you mic is connected.) Make sure you get levels here when talking or tapping the mic lightly. Sound max should work if this is set correctly.
Jun 24, 2009 | Intel D865GBF Motherboard
MSI 1996 Motherboard: Power on Signal to PS staying high
check motherboard wire conector, make sure its not reversed
Dec 23, 2008 | Intel Motherboard
VHF radio inop
yes try going to raidio shack and asking if they could fix it
Dec 13, 2008 | Humminbird Radio Communications
Computer monitor
disconnect the flyback transformer B+ POINT. if the tick sound goes the problem may be in the flyback transformer. replace the transformer.
Apr 07, 2008 | SAMTRON 55V 15" CRT Monitor
Via motherboard problem
Sounds like bad hard drive. disconnect power from it and see if tik goes away
Dec 24, 2007 | Computers & Internet
The Laptop Wont Even Start
Acer has the tendancy to blow it's regulator circuit, it makes a fast tik-tik-tik sound, if so, send in for repairs, nothing you can do to fix it. JJ
Sep 11, 2007 | Acer TravelMate 2355LCi Notebook
Gigabyte GA-8I915P Duo Pro Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
