Question about Philips CDR770 CD Recorder
Broken disc tray
I broke the disc tray that holds the cd. where can i get a tray to replace it?
    New Friend:
Hello,i have a problem with my Philips CDR 770 CD. .. I purchased lately on the internet 10 CD digital audio VERBATIM,but will not read them ... only reads the Philips digital audio,writable and rewritable,the repurchase ... I hope you can solve my problem ... THANKS
Posted on Mar 23, 2014
Disc removal
If this is a CD player, the belt broke to the CD tray. Need to open this up and replace the belt.
Oct 08, 2016 | Audio Players & Recorders
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
Disc tray
http://www.shop.philips.com/service/
This is a global service center. Maybe you can find it here.
Best of luck.
Mar 22, 2014 | Philips CDR770 CD Recorder
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
Nov 28, 2013 | Magnavox DV220MW9 DVD Player VCR
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Nov 19, 2012 | Lenovo Computers & Internet
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
My disc tray is broken
Yes just follow these steps
1)turn off your comp and open your cabinet..
2)disconnect the power and IDE cables connected to the drive
3)Unscrew the screws holding the top cover and lft the cover upwards..
4)Now you will be able to see the lens tray etc..Just locate it and gently push it to the correct position..
If its broken into two you will have to buy a new one..You a get it at any computer accessories shop..
Please comment before you rate..
Oct 22, 2007 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
Philips CDR770 CD Recorder Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
