Question about LG WM0642H Front Load
Main pcb or wiring
Le code
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Motor Overload problem
Posted on Mar 29, 2014
Le code
The LE code denotes problems with the motor and not the PCB
Mar 22, 2014 | LG WM0642H Front Load
Wm2077cw le error is there a reset button for that code
Your LG washing machine's motor is controlled by the main circuit board. This is the brain of your washing machine. Depending on the selected program and which cycle is currently running, the PCB will tell the motor which speed to run at and which direction to turn. The Hall Effect sensor on the main circuit board is fed operational feedback from the motor. If there is any difference between what the motor should be doing and what it is actually doing - the appliance will stop operating and display an "LE" error.
For example: if the main circuit board tells the motor to rotate clockwise at a certain speed and the motor doesn't start, the monitoring sensor will relay this inactivity to the main PCB and a "LE" error will persist. The same error would be displayed if the motor rotates in the wrong direction or runs at the wrong speed. It should be evident there are many faults that could produce the "LE" error code. Failure of one of the major components or a fault in the monitoring and feedback loop, could all lead to this problem. It is true however, some faults occur more regularly than others. Test for the most common causes of failure, eliminate them, and move on to more unlikely faults.
Many causes for the "LE" error are thought to stem from LG's manufacturing process. Many customers found the wiring damaged or completely severed in their washing machine's motor drive and feedback loop. If the wires were installed too close to a moving part, they may be vulnerable to mechanical wear once the machine starts to operate. A washing machine vibrates a lot during a spinning cycle, so it is conceivable wires could be damaged in this way. Check the cables feeding the motor for any obvious signs of damage. If you cannot see any problem, disconnect those wires and check for conductivity with a multi-meter. There should be almost no resistance detected in the wire.
If you find a damaged wire, replace it and ensure the new wire is well out of the way of any moving parts. If the wire is faultless you will have to move on and continue fault finding. Try and turn the motor's rotor by hand, if there is any real friction or if the rotor is seized - you will have to replace the motor. Faultless wiring and a washing machine motor - with the existence of an "LE" error code, indicates a fault in the main system board. It should be noted though; this is unlikely to be the cause of the problem. Almost all "LE" errors indicate faulty wiring - so ensure you have properly checked this before installing a new PCB.
Here is a link to the PCB board.
Pcb Assembly display
Mar 03, 2014 | LG WM-2277HW Front Load Washer
Le code (LE) ?
Display Condition LE = Motor Error.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Thanks and have a nice day.
Jul 03, 2011 | Dishwashers
Machine fills with water but will not rotate or spin just makes a noise then le error
Your LG washing machine’s motor is controlled by the main circuit board. This is the brain of your washing machine. Depending on the selected program and which cycle is currently running, the PCB will tell the motor which speed to run at and which direction to turn. The Hall Effect sensor on the main circuit board is fed operational feedback from the motor. If there is any difference between what the motor should be doing and what it is actually doing – the appliance will stop operating and display an “LE” error. For example: if the main circuit board tells the motor to rotate clockwise at a certain speed and the motor doesn’t start, the monitoring sensor will relay this inactivity to the main PCB and a “LE” error will persist. The same error would be displayed if the motor rotates in the wrong direction or runs at the wrong speed. It should be evident there are many faults that could produce the “LE” error code. Failure of one of the major components or a fault in the monitoring and feedback loop, could all lead to this problem. It is true however, some faults occur more regularly than others. Test for the most common causes of failure, eliminate them, and move on to more unlikely faults.
Many causes for the “LE” error are thought to stem from LG’s manufacturing process. Many customers found the wiring damaged or completely severed in their washing machine’s motor drive and feedback loop. If the wires were installed too close to a moving part, they may be vulnerable to mechanical wear once the machine starts to operate. A washing machine vibrates a lot during a spinning cycle, so it is conceivable wires could be damaged in this way. Check the cables feeding the motor for any obvious signs of damage. If you cannot see any problem, disconnect those wires and check for conductivity with a multi-meter. There should be almost no resistance detected in the wire.
If you find a damaged wire, replace it and ensure the new wire is well out of the way of any moving parts. If the wire is faultless you will have to move on and continue fault finding. Try and turn the motor’s rotor by hand, if there is any real friction or if the rotor is seized – you will have to replace the motor. Faultless wiring and a washing machine motor - with the existence of an “LE” error code, indicates a fault in the main system board. It should be noted though; this is unlikely to be the cause of the problem. Almost all “LE” errors indicate faulty wiring - so ensure you have properly checked this before installing a new PCB.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Washing Machines
Washer displays an le code, we have cleaned the filter and unplugged the washer, still getting the code. what do we do
LE ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy : Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
this is straight out of the repairmans manual on the le code...hope it helps you out!!!!
Oct 04, 2009 | LG WM1812C Front Load Washer
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
Washer is showing a le code and will not work
Jul 10, 2009 | LG WM-2077C Front Load Washer
ON MY LG WASHER THE LE LIGHT COMES ON MY WASHER IS A WM0532HW WHAT IS WRONG
Jul 10, 2009 | LG Washing Machines
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
LG WM0642H Front Load Logo
19 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
