Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Cant connect to wirless on xbox red light on adapter help
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Read the manual
Posted on Jun 14, 2009
When i plug my wirless xbox 360 internet adapter into my xbox it blinks red one time right when i plug it in then its just blank. wat am i doing wrong?
The adapter is bad it should turn on red and stay red until you set-up the wireless settings and then it will display green. If there is no light at all that usually mean the adapter has gone bad (I have had one go bad on me also). If by some chance you have some old routers laying around you should consider making your own wireless adapter/bridge by flashing dd-wrt (dd-wrt.com) onto both of them and setting one up as a bridge to connect your xbox too.
Mar 07, 2011 | Video Game Consoles & Games
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
Red Light On Wireless Adaptor For Xbox Live
just do port forwarding in the router and port number of the x box OK try it
Apr 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox wirless adapter
I had the same problem last week. Xbox Support says I need a new adapter, so I figured I would tinker around with the broken one. On the USB connector itself, there is a outer stainless shroud, and the inner black piece with the gold contacts on it. What happens is the wifi adapter contacts no longer touch the console contacts, hence the light never comes on and the console doesn't recognize it. I stuck a screwdriver between the stainless shroud and the black connector plate, and made the gap a little bigger, now the adapter works perfectly. I think this is a design flaw, as I never move the console or adapter, but over time, the pressure from the USB cable makes the contacts loose and it eventually no longer touches. Saved me $100 bucks.
Dec 30, 2008 | Microsoft Wireless Network Adapter Xbox...
XBOX NETWORK ADAPTER
this happened to me to it seems to be very common and xbox support knows nothing PS3 and WII RULE
Jul 25, 2008 | Microsoft Wireless Network Adapter Xbox...
Wireless adpater red!
try using WEP encryption, especially if you use a G router, as thid is easier for the adapter to work with then WPA. also make sure that you have the ports open for xbox Live, i think its ports 88 and 3074
Jun 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless connection
That is because of the radio frequency your wireless devices work on. Go to your router and change your wirless bandwitdth to the highest possible,.
May 24, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
353 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
